Hi users,
I am trying to use GPU capability of lammps on my laptop with Mac operating system. Specifically I tried GPU package installation following instructions available.
Following Makefile.mac with
CUDA_PRECISION = -D_DOUBLE_DOUBLE (As having Nvidia GT750M with CC3.0)
CUDA_ARCH = -arch=sm_35 (Tried 21,30 too)
NVCC = nvcc -m64
Able to get libgpu.a successfully for all three sm_21/30/35 values (which I explored from lammps mailing list posts for similar posts)
Still the error looks persistent. I will appreciate if you guys can give some suggestion to get this issue resolved. I am pasting the outcome of ./nvc_get_devices below
For the GT750M card, -arch=sm_30 is the correct compute capability setting. After modifying Makefile.mac, did you do “make -f Makefile.mac clean” and then “make -f Makefile.mac”?
Once libgpu.a is rebuilt, the LAMMPS binary should be re-linked with updated libgpu.a: i.e. in the src/ folder
rm lmp_foo; make foo
Hope it helps,
-Trung
Hi Trung,
Thanks for your advice.
I did it all from scratch for arch_sm=30 and now it is running benchmark and gpu example codes.
Though I did it previously but seems I forgot something in between.
A small query just for curiosity. What helps in deciding “arch_sm” value based on GPU card provided ?
Thanks for resolving the problem.
