ERROR: Illegal dump_modify command
Hey, Guys,
I am trying to run lammps 03032020 version on GPU nodes and getting the following error message:
ERROR: Illegal dump_modify command (src/dump.cpp:1143)
Last command: dump_modify trjNVT header yes time yes flush yes
Here is what I have in my input file, any help is appreciated.
print “"
print “NVT equilibration to partially melt hydrate at T=${Tdiss}”
print "
dump trjNVT_eql all custom 20000 NVT_eql_Trajectory.lammpstrj id mol type x y z ix iy iz vx vy vz
dump_modify trjNVT_eql header yes time yes flush yes
Sincerely,
Most likely, your LAMMPS version is (much) older than the version of LAMMPS documented in the manual you are consulting and thus you are using dump_modify options that are not supported by your LAMMPS version.
Thank you so much, Alex. I really appreciate your prompted response.
