Hello I’m going to add hydrodynamic forces on my particles with lattice boltzmann package and as the document says I have to use fix lb/rigid/pc/sphere command because I’m not using default coupling constant, but I get Illegal fix error:
fix flu all lb/fluid 5 1 3.0 0.864 setGamma 20 dx 2 noise 1 8979873 calcforce 1000 poly printfluid 1000
fix flow all lb/rigid/pc/sphere force 1 0 0 innerNodes ForceAtoms
Using a lattice-Boltzmann grid of 5 by 5 by 5 total grid points. (…/fix_lb_fluid.cpp:382)
ERROR: Illegal fix lb/rigid/pc/sphere command (…/fix_lb_rigid_pc_sphere.cpp:180)
which I have no idea of this problem. I’m using LAMMPS (1 Feb 2014) so I have user-lb package.
please answer my question
thanks
Hello I'm going to add hydrodynamic forces on my particles with lattice
lb/rigid/pc/sphere command because I'm not using default coupling constant,
(../fix_lb_fluid.cpp:382)
(../fix_lb_rigid_pc_sphere.cpp:180)
which I have no idea of this problem. I'm using LAMMPS (1 Feb 2014) so I
from http://lammps.sandia.gov/doc/Section_errors.html :
Illegal ... command
Self-explanatory. Check the input script syntax and compare to the
documentation for the command. You can use -echo screen as a
command-line option when running LAMMPS to see the offending line.
