Hi everyone,
I am trying to calculate scattering rate for a 2d spin polarized system, but I am getting this error mentioned below.
`indent preformatted text by 4 spaces`
/$$__ $$| $$$ /$$$ /$$__ $$| $$_____/|__ $$__/
| $$ \ $$| $$$$ /$$$$| $$ \__/| $$ | $$
| $$__ $$| $$ $$$| $$ \____ $$| $$__/ | $$
|__/ |__/|__/ |__/ \______/ |________/ |__/
v0.4.8
A. Ganose, J. Park, A. Faghaninia, R. Woods-Robinson,
A. Jain, in prep.
amset starting on 19 Feb 2021 at 11:51
Run parameters:
- scattering_type: ['ADP']
- doping: [-1.99e+14 -2.20e+15 -1.72e+16 -1.86e+17 -1.46e+18 -4.39e+18]
- temperatures: [300]
- soc: False
- zero_weighted_kpoints: prefer
- interpolation_factor: 5
- wavefunction_coefficients: wavefunction.h5
- use_projections: False
- free_carrier_screening: False
- high_frequency_dielectric:
[[ 11.70 0.00 0.00]
[ 0.00 11.70 0.00]
[ 0.00 0.00 11.70]]
- static_dielectric:
[[ 11.70 0.00 0.00]
[ 0.00 11.70 0.00]
[ 0.00 0.00 11.70]]
- elastic_constant:
[[ 366.0 99.0 5.0 0.0 0.0 -0.6]
[ 99.0 366.0 5.0 0.0 0.0 0.6]
[ 5.0 5.0 28.0 0.0 0.0 0.0]
[ 0.0 0.0 0.0 134.0 0.6 0.0]
[ 0.0 0.0 0.0 0.6 6.5 0.0]
[ -0.6 0.6 0.0 0.0 0.0 6.5]]
- deformation_potential: deformation.h5
- defect_charge: 1
- compensation_factor: 2
- energy_cutoff: 1.5
- fd_tol: 0.05
- dos_estep: 0.01
- symprec: 0.01
- nworkers: -1
- cache_wavefunction: True
- calculate_mobility: True
- separate_mobility: True
- mobility_rates_only: False
- file_format: json
- write_input: False
- write_mesh: True
- print_log: True
- write_log: True
~~~~~~~~~~~~~~~~~~~~~~~~~~~~ STRUCTURE ~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Structure information:
- formula: CrI3
- # sites: 8
- space group: P3-1m
Lattice:
- a, b, c [angstrom]: 7.06, 7.06, 21.06
- a, b, y [deg]: 90, 90, 120
~~~~~~~~~~~~~~~~~~~~~~~~~~ BAND STRUCTURE ~~~~~~~~~~~~~~~~~~~~~~~~~
Input band structure information:
- # bands: 72
- # k-points: 120
- Fermi level: -2.992 eV
- spin polarized: True
- metallic: False
Band gap:
- indirect band gap: 1.131 eV
- direct band gap: 1.148 eV
- direct k-point: [0.14, 0.14, 0.00], [0.50, 0.00, 0.00]
Valence band maximum:
- energy: -3.109 eV
- k-point: [0.16, 0.16, 0.00]
- band indices: 30(Up), (Down)
Conduction band minimum:
- energy: -1.977 eV
- k-point: [0.33, 0.33, 0.00]
- band indices: 31(Up), (Down)
~~~~~~~~~~~~~~~~~~~~~~~~~~ INTERPOLATION ~~~~~~~~~~~~~~~~~~~~~~~~~~
Getting band interpolation coefficients
- time: 0.2467 s
Interpolation parameters:
- k-point mesh: 27x27x7
- energy cutoff: 1.5 eV
Interpolating spin-up bands 19-34
- time: 0.1443 s
Interpolating spin-down bands 17-30
- time: 0.1293 s
Generating tetrahedron mesh vertices>
> - time: 0.0903 s
> Initializing tetrahedron band structure
> - time: 0.6108 s
Initializing momentum relaxation time factor calculator
Initializing wavefunction overlap calculator
Desymmetrizing k-point mesh
- Found initial mesh: 18.000 x 18.000 x 18.000
- Integer mesh: 18 x 18 x 18
- Using 48 symmetry operations
Desymmetrizing wavefunction coefficients
- time: 1.3853 s
ERROR: amset exiting on 19 Feb 2021 at 11:51
File "Si.py", line 37, in <module>
amset_data = runner.run()
File "/home/ajay/amset/amset/core/run.py", line 61, in run
mem_usage, (amset_data, usage_stats) = memory_usage(
File "/home/ajay/.local/lib/python3.8/site-
packages/memory_profiler.py", line 336, in memory_usage
returned = f(*args, **kw)
File "/home/ajay/amset/amset/core/run.py", line 110, in
_run_wrapper
amset_data, interpolation_time = self._do_interpolation()
File "/home/ajay/amset/amset/core/run.py", line 221, in
_do_interpolation
amset_data.set_overlap_calculator(overlap_calculator)
File "/home/ajay/amset/amset/core/data.py", line 119, in
equal = check_nbands_equal(overlap_calculator, self)
File "/home/ajay/amset/amset/core/data.py", line 539, in
check_nbands_equal
nbands_equal = [
File "/home/ajay/amset/amset/core/data.py", line 540, in
<listcomp>
amset_data.energies[s].shape[0] == interpolator.nbands[s]
KeyError: <Spin.down: -1>
thank you for the help in advance
