hello dear
i want to simulate water and nano fluid cu in a fcc lattice…water is base fluid and cu is a region (sphere or box)in the center of lattice (between water)
molecules are in the range of 1000 to 1500 and cu atoms are about 400 to 500
when it runs it shows this error
:ERROR: Invalid atom type in create_atoms command (…/create_atoms.cpp:55)
group hydrogen type 1
748 atoms in group hydrogen
group Water type 1 2
1122 atoms in group Water
group cu type 3
0 atoms in group cu
group oxygen type 2
374 atoms in group oxygen
Cu
lattice fcc " 3. 610"
Lattice spacing in x,y,z = 3 3 3
region Cu sphere 0 0 0 7 units box
create_atoms 3 region Cu
this is my input script:
modified
units real
atom_style full
bond_style harmonic
angle_style harmonic
kspace_style pppm 1.0e-4
#kspace_modify force/disp/real …
#kspace_mdofiy force/disp/kspace …
Atom Definition
Water
read_data water.data
group cu type 3
group oxygen type 2
Cu
set group oxygen charge -1.040
set group hydrogen charge .520
set group cu charge 0.000
pair interaction
#sigma=3.157 epsilon=0.1521
pair_style hybrid eam lj/cut/coul/long 0.1521 3.157 lj/cut 3.157
pair_coeff 1 1 lj/cut/coul/long 0.0460 0.4000 # 108.0e-21 32.0e-11
pair_coeff 1 2 lj/cut/coul/long 0.0836 1.7753
pair_coeff 1 3 lj/cut 3.157 0.1521
pair_coeff 2 2 lj/cut/coul/long 0 0 # 0.1521 3.157
pair_coeff 2 3 lj/cut 3.157 0.1521
pair_coeff 3 3 eam cu.eam
bond_coeff 1 33.5315 3.3572
angle_coeff 1 2.181383 331.52
setting
fix 1 Water nvt temp 300.0 300.0 0.01
---------- compute ---------------------
#compute Tliq water temp
#compute Tpar water temp/partial
#compute heat/flux
#compute temp/profile or compute 1 all temp
#compute peatom all pe/atom
#compute keatom all ke/atom
---------- Relaxation ---------------------
min_style fire
min_modify dmax 0.01 line forcezero
minimize 1.0e-15 1.0e-15 1000000 10000000
dump 1all xyz 1000final.xyz
---------- output---------------------
thermo_style custom step (temp) c_Tliq c_Tpar etotal enthalpy pe press vol
thermo 100
thermo_modify flush yes
timestep 2.0
velocity water create 300.0 34239 rot yes dist gaussian
run 60000
