error in fix adapt command
I want to calculate free energy from lammps using compute ti command.I
get the problem illegal fix adapt command. please help me to fix this
error.
My input file is-
units real
kspace_style pppm 1.0e-4
kspace_modify order 3
atom_style full
pair_style lj/cut/coul/cut 15.0
bond_style harmonic
angle_style harmonic
pair_modify mix arithmetic
read_data datafile
neighbor 2.0 bin
neigh_modify delay 0 every 1 check yes one 10000 page 1000000
group ion type 1
group wtr type 2 3
minimize 1.0e-4 1.0e-6 1000 10000
variable lambda equal 0.01
variable scale1 equal ramp(1,0.01)
variable dscale1 equal 1
variable c equal ramp(1,0.01)
variable dc equal 1
variable ks equal ramp(3,1)
variable dks equal 1
compute er all ti lj/cut v_scale1 v_dscale1 coul/cut v_c v_dc kspace v_ks v_dks
fix 10 all adapt 10 pair lj/cut epsilon 1 2 v_scale1 pair coul/cut
scale 1 1 v_c scale yes reset yes
fix 2 all npt temp 300.0 300.0 100.0 iso 1.00 1.00 1000.0
timestep 1.0
thermo 100
thermo_style custom step temp vol etotal c_er
restart 100000 restart
dump 6 all custom 1000 free.dump id mol type x y z
run 800000
this means your fix adapt command syntax is wrong or unreasonable. Just compare with the mannual one word by one word carefully. You can find the wrong point. Sometimes it is just one extra letter that give you error. The detailed explanation is: http://lammps.sandia.gov/doc/fix_adapt.html
Have a good day!
I assume that in your script the fix adapt command
is really on one line in your script, not two lines as it shows in the email
below? If any command spans 2 lines then you need
a continuation character "&" at the end of the 1st line.
