following OpenKIM · Obtaining KIM Models · Interatomic Potentials and Force Fields I wanted to install model, but it failed:
(kim-env) miroi@MiroPhenomII-X6:~/work/git-projects/open-collection/theoretical_chemistry/software/openkim-ase/buildup_on_servers/wsl2/wsl2_win10_MiroPhenomII-X6/.kim-api-collections-management install user SW_StillingerWeber_1985_Si__MO_405512056662_005
Downloading.............. SW_StillingerWeber_1985_Si__MO_405512056662_005
/home/miroi/miniconda3/envs/kim-env/bin/kim-api-collections-management: line 487: 7662 Illegal instruction (core dumped) ${cmake_command} ../ -DKIM_API_INSTALL_COLLECTION="`printf ${install_collection} | tr "[:lower:]" "[:upper:]"`" > ./cmake-log.txt 2>&1
CMake Warning at /home/miroi/miniconda3/envs/kim-env/share/cmake/kim-api/kim-api-pre-2.2-compatibility.cmake:48 (message):
Pre 2.2.0 KIM-API package behavior is deprecated and will be removed in
3.0.0. Please update your CMakeLists.txt file to use a find_package()
signature similar to one of the following:
find_package(KIM-API 2.2 REQUIRED CONFIG)
find_package(KIM-API-ITEMS 2.2 REQUIRED CONFIG)
See the examples in the KIM API source package for more details.
Call Stack (most recent call first):
/home/miroi/miniconda3/envs/kim-env/share/cmake/kim-api/kim-api-config.cmake:49 (include)
CMakeLists.txt:36 (find_package)
Aborting!
Well, switching to direct installation instead of conda…
Hi Miroslav,
Let me know if building from source works from you, otherwise we can try to debug your Conda installation. I’ve never seen that bug before, so I’d be curious to see what’s causing it.
The first thing that jumps out at me is that you are invoking kim-api-collections-management at a path not inside your conda environment. Is ~/work/git-projects/open-collection/theoretical_chemistry/software/openkim-ase/buildup_on_servers/wsl2/wsl2_win10_MiroPhenomII-X6/.kim-api-collections-management a symlink to /home/miroi/miniconda3/envs/kim-env/bin/kim-api-collections-management?
EDIT: I think the terminal output may just look strange to me, are you just invoking kim-api-collections-management normally, e.g. without any prefix path or anything?
Hi Miroslav,
Another thing, probably unrelated, but may incidentally solve your problem and/or help in debugging – SW_StillingerWeber_1985_Si__MO_405512056662_005 is an outdated version. You can try installing SW_StillingerWeber_1985_Si__MO_405512056662_006 and see if that makes a difference (I doubt it, but worth a try).
And one final comment is that we generally recommend using the system collection when using Conda. Normally the system collection is inaccessible without sudo, but with a Conda installation, the system collection is inside the Conda environment, so it makes sense to use system instead of user, that way everything is contained inside the environment.
Well, another problem, with from the source installed KIM. I installed kimpy using pip, but got error:
(venv) miroi@MiroPhenomII-X6:~/work/git-projects/open-collection/theoretical_chemistry/software/openkim-ase/runs/kimpy_example/.python kimpy_example.py
File "/home/miroi/work/git-projects/open-collection/theoretical_chemistry/software/openkim-ase/runs/kimpy_example/kimpy_example.py", line 37, in <module>
units_accepted, kim_model = kimpy.model.create(
RuntimeError: Unable to create a new KIM-API Model object!
Fixed, after installing the potential file:
(venv) miroi@MiroPhenomII-X6:~/work/git-projects/open-collection/theoretical_chemistry/software/openkim-ase/runs/kimpy_example/.kim-api-collections-management install user EAM_Dynamo_ErcolessiAdams_1994
_Al__MO_123629422045_005
Downloading.............. EAM_Dynamo_ErcolessiAdams_1994_Al__MO_123629422045_005
This item needs its driver 'EAM_Dynamo__MD_120291908751_005', but it is not currently installed.
Trying to find it at openkim.org.
Downloading.............. EAM_Dynamo__MD_120291908751_005
[100%] Built target EAM_Dynamo__MD_120291908751_005
Install the project...
-- Install configuration: "Release"
-- Installing: /home/miroi/.kim-api/2.4.1+GNU.GNU.GNU.2026-01-02-19-24-56/model-drivers-dir/EAM_Dynamo__MD_120291908751_005/libkim-api-model-driver.so
-- Set non-toolchain portion of runtime path of "/home/miroi/.kim-api/2.4.1+GNU.GNU.GNU.2026-01-02-19-24-56/model-drivers-dir/EAM_Dynamo__MD_120291908751_005/libkim-api-model-driver.so" to ""
[100%] Built target EAM_Dynamo_ErcolessiAdams_1994_Al__MO_123629422045_005
-- Installing: /home/miroi/.kim-api/2.4.1+GNU.GNU.GNU.2026-01-02-19-24-56/portable-models-dir/EAM_Dynamo_ErcolessiAdams_1994_Al__MO_123629422045_005/libkim-api-portable-model.so
-- Set non-toolchain portion of runtime path of "/home/miroi/.kim-api/2.4.1+GNU.GNU.GNU.2026-01-02-19-24-56/portable-models-dir/EAM_Dynamo_ErcolessiAdams_1994_Al__MO_123629422045_005/libkim-api-portable-model.so" to ""
Success!
Distance Energy
1.0000000000e+00 8.3309698035e+00
1.5000000000e+00 4.0612306870e+00
2.0000000000e+00 1.8021700693e-02
2.5000000000e+00 -1.9353325249e+00
3.0000000000e+00 -1.7714986219e+00
3.5000000000e+00 -1.1478765871e+00
4.0000000000e+00 -4.9042072724e-01
4.5000000000e+00 -2.0418576357e-01
5.0000000000e+00 -1.1762679400e-01
5.5000000000e+00 -5.0038462875e-03
6.0000000000e+00 0.0000000000e+00
Great! You may already know this, but when you get a generic kimpy error, kim.log will often have more detailed information.
Well, this download is currently not working …
(venv) miroi@MiroPhenomII-X6:~/work/git-projects/open-collection/theoretical_chemistry/software/openkim-ase/runs/rare_gas_tests/Og_solid/melting/.kim-api-collections-management install user LJ_ElliottAkerson_2015_Universal__MO_959249795837_003
Downloading.............. LJ_ElliottAkerson_2015_Universal__MO_959249795837_003
Unable to download LJ_ElliottAkerson_2015_Universal__MO_959249795837_003 from https://openkim.org. Check the KIM Item ID for errors.
'wget' returned error code 8.
Aborting!
2026-01-02:21:25:57CET * 0 * information * 0x25f836f0 * KIM_LogImplementation.cpp:107 * Log object created. Default verbosity level is 'information'.
2026-01-02:21:25:57CET * 1 * error * 0x25f836f0 * KIM_CollectionsImplementation.cpp:725 * Unable to find item.
2026-01-02:21:25:57CET * 2 * information * 0x25f836f0 * KIM_LogImplementation.cpp:119 * Log object destroyed.
Yes, looks like some issues with our website.
https://openkim.org/id/LJ_ElliottAkerson_2015_Universal__MO_959249795837_003
is very slow to load for me. I will inform our webmaster and let you know if there are any updates, but it’s likely we are simply being spammed by bots and it will come back up on its own. The new expansion of our testing framework to 30,000+ multi-species crystals, and the corresponding upgrade to our website, has seemingly attracted a swarm of bots.
works,
all is fine, this thread can be considered as solved
This item needs its driver 'LJ__MD_414112407348_003', but it is not currently installed.
Downloading.............. LJ__MD_414112407348_003
[100%] Built target LJ__MD_414112407348_003
-- Installing: /home/miroi/.kim-api/2.4.1+GNU.GNU.GNU.2026-01-02-19-24-56/model-drivers-dir/LJ__MD_414112407348_003/libkim-api-model-driver.so
-- Set non-toolchain portion of runtime path of "/home/miroi/.kim-api/2.4.1+GNU.GNU.GNU.2026-01-02-19-24-56/model-drivers-dir/LJ__MD_414112407348_003/libkim-api-model-driver.so" to ""
[100%] Built target LJ_ElliottAkerson_2015_Universal__MO_959249795837_003
-- Installing: /home/miroi/.kim-api/2.4.1+GNU.GNU.GNU.2026-01-02-19-24-56/portable-models-dir/LJ_ElliottAkerson_2015_Universal__MO_959249795837_003/libkim-api-portable-model.so
-- Set non-toolchain portion of runtime path of "/home/miroi/.kim-api/2.4.1+GNU.GNU.GNU.2026-01-02-19-24-56/portable-models-dir/LJ_ElliottAkerson_2015_Universal__MO_959249795837_003/libkim-api-portable-model.so" to ""
Success!
