error in lammps input script
Dear Axel and Users,
I am getting an error when I run my gcmc simulation. in case of molecular template command like offset. I give a brief view of my file set up in input script belo
units real
atom_style full
atom_modify map array
pair_style lj/cut 12.5
variable a loop 8
variable p index 0.8 0.85 0.9 0.95 1.0 1.05 1.1 1.15
molecule gas gas1.molecule offset 4 0 0 0 0 # molecule templates
read_data cua1.data
log log Cu_D_$a
molecule gas gas2.molecule # molecule templates
molecule gas gas2.molecule 4 0 0 0 0 # molecule templates
Define interatomic potential
pair_coeff 1 5 0.0664 3.1275 #Ni
pair_coeff 3 5 0.16771 3.3815 #O
pair_coeff 2 5 0.16718 3.6015 #C
pair_coeff 4 5 0.06684 3.288 #H
pair_coeff 5 * 0.053649 2.8 #gas
pair_coeff 6 * 0.156973 3.05
Define groups fixes computes (see LAMMPS manual)
group gas type 5 6
group sol type 1 2 3 4
neigh_modify exclude molecule sol
neigh_modify exclude molecule gas
fix 1 all rig nvt temp 298 2 0
fix 2 gas gcmc 1 1000 1000 0 3366593 298.0 -0.5 0.1 mol gas pressure $p fugacity_coeff 1
fix 1 gas gcmc 100 10 10 0 34565 300.0 -0.5 0.1 maxangle 10.0 mol gas
Simulation data output and dump options
compute_modify thermo_temp dynamic yes
log Cu_DO_$a
thermo 10
thermo_style custom step atoms vol cella cellb cellc cellalpha cellbeta cellgamma
dump 2 all custom 1 dump_all id type x y z
dump m1 all image 1 all*.jpg type type view 0.0 45
dump aa gas image 5 gas.*.jpg type type
input script belo
this input is too complex to give any recommendation.
also, there seem to be comment characters missing, so it is difficult to
tell which is intended input and which is not.
you also have been violating multiple mailing list etiquette
recommendations.
i suggest you do the following:
- simplify your input deck to have *only* lines that are essential.
- remove the loop, molecule, fix gcmc commands, so that you have a simple
input running a short trajectory on your framework system. make sure that
can finish and produces meaningful energies and trajectory
- add the molecule command(s), and test it without using gcmc but just
create a single molecule using "create_atoms 0 single ... mol gas 555" at a
suitable location and also verify, that this will create a meaningful
trajectory and energies. if you get an error about your molecule file,
reread the documentation of the molecule command *very* carefully. i have
copied your molecule file and it can be read in using "*molecule gas
gas2.molecule", "**molecule gas gas2.molecule 4 0 0 0 0"* is incorrect
syntax, and "*molecule gas gas2.molecule offset 4 0 0 0 0*" generates atoms
with out of range (= invalid) atom types.
- add and debug your fix gcmc command
you should only be posting to the mailing list, if you can provide a small,
simple and complete input deck.
please also remember to *always* report what LAMMPS version you are using
and on what platform and in the future please refrain from hijacking other
threads (i.e. posting your inquiry as a reply to an e-mail on a completely
different subject).
thanks for your understanding,
