I get an error in following command:
$ qlaunch singleshot
2016-09-14 16:03:28,156 INFO moving to launch_dir /home/python/queue_tests
2016-09-14 16:03:28,162 INFO submitting queue script
2016-09-14 16:03:28,246 ERROR ----|vvv|----
2016-09-14 16:03:28,246 ERROR Could not parse job id following sbatch due to error a bytes-like object is required, not 'str'...
2016-09-14 16:03:28,249 ERROR Traceback (most recent call last):
File "/home/python/sf_box/fireworks/fireworks/user_objects/queue_adapters/common_adapter.py", line 200, in submit_to_queue
job_id = self._parse_jobid(p.stdout.read())
File "/home/python/sf_box/fireworks/fireworks/user_objects/queue_adapters/common_adapter.py", line 71, in _parse_jobid
for l in output_str.split("\n"):
TypeError: a bytes-like object is required, not 'str'
2016-09-14 16:03:28,250 ERROR ----|^^^|----
2016-09-14 16:03:28,250 ERROR ----|vvv|----
2016-09-14 16:03:28,250 ERROR Error writing/submitting queue script!
2016-09-14 16:03:28,256 ERROR Traceback (most recent call last):
File "/home/python/sf_box/fireworks/fireworks/queue/queue_launcher.py", line 133, in launch_rocket_to_queue
launchpad.set_reservation_id(launch_id, reservation_id)
File "/home/python/sf_install/python/3.5.2/lib/python3.5/contextlib.py", line 77, in __exit__
self.gen.throw(type, value, traceback)
File "/home/python/sf_install/python/3.5.2/lib/python3.5/site-packages/monty-0.9.1-py3.5.egg/monty/os/__init__.py", line 32, in cd
yield
File "/home/python/sf_box/fireworks/fireworks/queue/queue_launcher.py", line 130, in launch_rocket_to_queue
raise RuntimeError('queue script could not be submitted, check queue '
RuntimeError: queue script could not be submitted, check queue script/queue adapter/queue server status!
2016-09-14 16:03:28,256 ERROR ----|^^^|----
But i get the correct result:
$ls
FW_job-2315017.error FW.json fw_test.yaml logging my_launchpad.yaml
FW_job-2315017.out FW_submit.script howdy.txt my_fworker.yaml my_qadapter.yaml
$ cat howdy.txt
howdy, your job launched successfully!
$ cat FW_job-2315017.out
2016-09-14 16:03:23,198 INFO Hostname/IP lookup (this will take a few seconds)
2016-09-14 16:03:23,201 INFO Launching Rocket
2016-09-14 16:03:24,258 INFO RUNNING fw_id: 1 in directory: /home/queue_tests
2016-09-14 16:03:24,265 INFO Task started: ScriptTask.
2016-09-14 16:03:24,283 INFO Task completed: ScriptTask
2016-09-14 16:03:24,590 INFO Rocket finished
$ cat my_qadapter.yaml
_fw_name: CommonAdapter
_fw_q_type: SLURM
rocket_launch: rlaunch -w /home/python/queue_tests/my_fworker.yaml -l /home/python/queue_tests/my_launchpad.yaml singleshot
ntasks: 1
cpus_per_task: 1
ntasks_per_node: 1
walltime: '00:02:00'
queue: null
account: null
job_name: null
logdir: /home/python/queue_tests/logging
pre_rocket: null
post_rocket: null
#You can override commands by uncommenting and changing the following lines:
#_q_commands_override:
#submit_cmd: my_qsubmit
#status_cmd: my_qstatus
#You can also supply your own template by uncommenting and changing the following line:
#template_file: /full/path/to/template
Am i make mistakes?
