read_data water.data
hello dear
when ir run the input code .it shows this error “illegal neighbor command”
i read the manuel and did like the commands and modified it again it shows the same error.
can anybody helm me
thanks
regard
units real
atom_style full
bond_style harmonic
angle_style harmonic
kspace_style pppm 1.0e-5
group hydrogen type 1
group Water type 1 2
group cu type 3
group oxygen type 2
#+++++++++++++++++>>Cu
lattice fcc " 3. 615" #Cu lattice constant
region Cu sphere 0 0 0 7 units box
create_atoms 3 region Cu
hello dear
when ir run the input code .it shows this error "illegal neighbor command"
the same error.
...and it will keep showing you the same errors because your input is
*not* how it is required.
you had the same kind of error before. you obviously didn't type
anything but used cut and paste, but cut and paste these days doesn't
work reliably. PDF viewers and web browsers insert "invisible" spaces
and non-ASCII characters into what you see on the screen for more
readable and better formatting. this if you just blindly cut and paste
and not check what is actually typed on a character by character basis
(thus it is best to use a real plain text editor for text input like
LAMMPS needs it), you will have the same problem over and over again.
a smart person will check this when this happened the first time and
analyse and understand previous mistakes and then learn from them.
can anybody helm me
how long do you think you can keep on doing this?
this mailing list is not a place where you can outsource your entire
thinking and problem solving. sooner or later you will have worn out
even the most generous people on the list that may still be willing to
help you at the moment because of your unparalleled ignorance,
carelessness and lack of effort to *understand* the problems you run
into. that is probably going to be the time where you run into a
problem that would actually warrant to get help from this list, but by
that time everybody will have flagged you as a person that is
primarily a nuisance and not showing any respect to the people that
did provide help and good advice.
