Dear LAMMPS Users,
Hello LAMMPS Users. I would like to ask a question in regards to defining the coefficients for pair_styles
I have a simulation box consisting of Type 1 and Type 2 atoms.
Lennard-Jones potential with cutoff distance of 2.5 is applied between Type 1 atoms.
Likewise, DPD potential is applied between Type 1 and Type 2 atoms.
I run this initial stage for 50000 timesteps.
After 50000 timesteps, I would like to switch the DPD potential applied between Type 1 and Type 2 atoms to DPD thermostat and Lennard-Jones potential with a cutoff distance of 1.122462 and run this second stage for 10000 timesteps.
The LJ potential between Type 1 atoms will remain as it is throughout the entire simulation.
I have displayed a portion of my input script:
pair_style hybrid lj/cut 2.5 dpd 1.0 1.0 122347
read_data DataFile
pair_coeff 1 1 lj/cut 1.0 1.0 2.5
pair_coeff 1 2 dpd 25 4.5 1.0
pair_modify shift yes
timestep 0.010
reset_timestep 0
fix 1 all nve
fix 2 all press/berendsen iso 0.0 0.0 10.0
group mol type 2
velocity mol create 1.0 17786140
run 50000
pair_style hybrid/overlay lj/cut 1.122462 dpd/tstat 1.0 1.0 1.122462 122347
pair_coeff 1 2 lj/cut 1.0 1.0 1.122462
pair_coeff 1 2 dpd/tstat 4.5 1.122462
run 10000
However, I am obtaining an error occurring at run 50000 which states "All pair coeffs are not set.’
Observing the portion of the input script that I have displayed above, I believe that all pair coefficients are specified by the pair_coeff command. Therefore, I am not sure where the source of the error is.
I tried another way by re-specifying the pair_coeffs in the my external DataFile via read-data command:
Pair Coeffs
2 dpd 25 4.5 1.0
In this case, my simulation ran for the first 50000 timesteps, but I received an error at the start of the second stage:
Unknown identifier in data file: 2 dpd/tstat 4.5 1.122462
I have referred to the manual but I am not finding the source of the error. I would greatly appreciate if anyone could provide me with any advice or comments. Thank you so much for your time.
Sincerely,
Masato Koizumi
