Dear Lammps Users,
I want to do NVT simulation of azide ion (N-N-N)-1 in 107 water molecules
using lammps.I want to keep the azide molecule fixed at 180 degrees or at best
linear.I tried using fix shake for the azide and water molecule but I get the error
saying
ERROR: More than one fix shake (../fix_shake.cpp:307)
I tried using fix rigid/nvt/small but then it gives error
ERROR: Invalid fix style (../modify.cpp:714)
Initial input file description is given below,any suggestion would be highly acknowledged.
units real
kspace_style ewald 1.0e-4
kspace_modify order 3
atom_style full
pair_style lj/cut/coul/long 9.0
bond_style harmonic
angle_style harmonic
pair_modify mix arithmetic
newton off
read_data azide.data
#read_restart restartfile
group azd type 2
group hyd type 1
group oxy type 3
group wtr type 1 3
set atom 1 charge -0.9215
set atom 3 charge -0.9215
set group hyd charge 0.41
set group oxy charge -0.82
neighbor 3.0 bin
neigh_modify delay 0 every 1 one 6000
minimize 1.0e-4 1.0e-6 100 1000
fix 1 wtr shake 0.0001 20 0 t 1 3 a 2 b 1
fix 2 azd shake 0.0001 20 0 t 2 a 1 b 2
#fix 2 azd rigid/nvt/small group temp 300.0 300.0 100.0
fix 3 all nvt temp 300.0 300.0 100.0
#fix 2 all npt temp 300.0 300.0 100.0 iso 1.0 1.0 1000.0
# fix 2 all nve
# fix 3 all temp/rescale 5000 300.0 300.0 0.005 1.0
compute ab all rdf 200 1 1 1 2 1 3 2 2 2 3
compute bc all msd com yes
fix 4 all ave/time 100 1 100 c_ab file rdf.out mode vector
fix 5 all ave/time 100 1 100 c_bc file msd.out mode vector
timestep 1.00
thermo 10000
thermo_style custom step pe ke etotal temp press vol
restart 50000 z.restart
dump 2 all custom 1000 z1.output.dump id type x y z
dump 3 all custom 1000 z2.output.dump id type fx fy fz
run 2500000
Dear Deepak,
If you send me your data file azide.dat (off-list), I can look into this.
Peter
The error regarding fix rigid probably means you did not install the rigid package. In your LAMMPS src-directory you can run
make yes-rigid
and then recompile to enable them.
And the SHAKE error follows what the doc page says:
For computational efficiency, there can only be one shake or rattle fix defined in a simulation.
Is there a reason you can’t define all the bonds, etc you want constrained
in one command?
Only allowing one fix shake commands prevents users from
trying to do something that won’t work, like having overlap
between the 2 sets of constrained bonds and thinking that would
get around the restriction that your SHAKE clusters cannot be
very large. Overlap meaning common atoms betwee two
fix shake commands.
Dear Sir,
Thanks for your informative answer,
What I intend to do is that simulate azide in water, I need to keep azide structure linear
and water in its V shaped form.In my lammps data file I have two bond angle kinds corresponding to N-N-N
and H-O-H angle.So I tried defining a group azd for three Nitrogen atoms and group wtr consisting of water molecules.
Finally I invoke fix shake for the two groups without mixing on description to lammps,
as per as your suggestion I clubbed both the constraints in single fix-shake
fix 1 all shake 0.0001 20 0 t 1 2 3 a 1 2 b 1 2
however then the simulation crashes with the segmentation fault.Finally if I use just
fix shake on water group
it indeed ran smoothly.
Please let me know whatever is needed to be done.
Thanks again
Dear Sir,
structure linear
to lammps,
the SHAKE constraint solver as implemented in LAMMPS cannot handle 180
degree angles.
so you'd *have* to use one of the fix rigid styles (or start
programming a suitable subroutine into fix shake that detects and
turns such 3 atomic linear constructs into a single bond constraint
between two virtual sites and then projects the results back to the
original atoms).
use just
yes. water is fine. it is the azide anion that is trouble.
the best option is probably to make sure that all molecules have
unique molecule ids and then use one of the fix rigid/small styles to
do both the time integration and maintaining rigidity for both kinds
of molecules. same as for the shake fix, you want to keep the
communication overhead small and thus just use a single rigid fix.
(and one of the rigid/small styles, since those have optimized
communication for a system like yours with many small rigid objects).
You can’t use SHAKE to keep a triatomic molecule linear (this is a mathematical issue with the algorithm, not a problem with LAMMPS). There are a couple of possibilities:
- use a rigid integrator instead
- use SHAKE to keep the bonds fixed, and apply a potential to the angle to try to keep it linear (this will result in oscillations about linearity, but may be sufficient for your purposes)
