Error: Invalid fix style for fix move rotate
Dear users,
I get the following error in the logfile:
fix 14 top move rotate 0 0 0 0 0 -1 120 units box
ERROR: Invalid fix style
Can you see whats wrong with my fix move rotate command?
Here are some of the commands which precede the fix move rotate
velocity bottom set 0 0 0 sum no units box
velocity top set 0 0 0 sum no units box
fix hold1 top setforce 0 0 NULL
fix hold2 bottom setforce 0 0 NULL
unfix hold1
unfix hold2
fix 15 bottom move rotate 0 0 0 0 0 1 120 units box
group top is the atoms on the top end of a CNT
group bottom is the atoms on the bottom end of a CNT
Possibly relevant info:
My boundary conditions are f f f
I am using LAMMPS May 2009 edition
Daniel
Daniel Mulvihill
Government of Ireland Research Fellow,
Department of Mechanical, Aeronautical, and Biomedical Enginering,
University of Limerick
Dear users,
invalid fix style means that you have an executable that does not
contain fix move at all or that you have non-ascii characters in that
line, e.g. the space between move and rotate is not a proper space. in
that case the parser will use "move rotate" as the fix style...
this is insanity. nobody will care about things not working with a 4+
year old version.
just checked the SCM repository history. fix move was apparently added
to LAMMPS in december 2009.
Does the old version even have a src/fix_move.cpp?
You cannot use the current web pages with old versions
and expect them to be compatible.
Dear Axel and Steve,
No Steve it doesn’t seem to have a fix move.cpp!!!
Thanks for checking this Axel. It seems the problem is surely that I’m using such an old version.
Will work on making the latest version ASAP
Daniel
