Hi !!!
I have already successfully compile Lammps including reax and reax/c without errors.
What I did was the following:
- Download the last version of lammps and the patch from August 12/ 2012
- Unzip and untar lammps.
- Install the patch.
- go to into lammps/lib/reax
- compile the library: make -f makefile.gfortran
- copy the content of Makefile.lammps.gfortran in Makefile.lammps
- go to lammps/src
- make yes-reax
- make yes-user-reaxc
- compile lammps make openmpi
Unfortunately, when I try to run the examples (AB, .rdx and .tatb ), I obtain an error:
Error: Invalid pair style
Can You help me?
John Michael Espinosa Duran
PhD Student
Indiana university
PD: Also, I tried only with reax, and then only with reaxc, and it does not works.
Hi Jhon Michael,
It seems your executable was not successfully compiled. Type
"lmp_openmpi -h" and see if you have reax and reax/c listed within
pair styles. Also, if you downloaded the latest version you wouldn't
need to install the patch.
Ray
Ho John Michael,
It seems you still don't have reax or reax/c installed. If you do
"lmp_openmpi -h", you have to have lmp_openmpi in your bin path,
otherwise go to /src and do "./lmp_openmpi -h".
See this webpage for how to make lammps with optional packages:
http://lammps.sandia.gov/doc/Section_start.html#start_3
Ray
Dear Ray
Ok, I did ./lmp_openmpi-h, and for pair styles, it includes reax/c and reax, I attached what I obtained for pair styles.
To include the packages, I did the information included in the link that you send me but instead of “make g++”, I did “make openmpi”
Then I do not why I obtain invalid par style when I try to run the examples.
Thanks for your collaboration.
John Michael
Pair styles: adp airebo beck bop born/coul/long born/coul/wolf born buck/coul/cut buck/coul/long buck comb coul/cut coul/debye coul/long coul/wolf dpd dpd/tstat eam/alloy eam/fs eam eim gauss hbond/dreiding/lj hbond/dreiding/morse hybrid hybrid/overlay lcbop lj96/cut lj/charmm/coul/charmm lj/charmm/coul/charmm/implicit lj/charmm/coul/long lj/cubic lj/cut/coul/cut lj/cut/coul/debye lj/cut/coul/long lj/cut/coul/long/tip4p lj/cut lj/expand lj/gromacs/coul/gromacs lj/gromacs lj/smooth lj/smooth/linear morse reax/c reax rebo soft sw table tersoff tersoff/zbl yukawa
The examples are very standard, and if you do have reax or reax/c
successfully installed you should be able to run them without a
problem. Please check if you have the executable, which is compiled
with reax or reax/c, located, copied or symbolic linked to the
example/reax dir where you are trying to run. That could be the only
reason I can think of.
Ray
