Dear Lammpsers,
I am permanently facing with the lost atoms error and I don’t know why.
I think there is something wrong with “lattice sq2” command actually. Since, I deactivated the "fix nvt "command and applied instead the "fix nve "command in order to check whether the initial crystal structure is correct or not and it did not work! So, I think that lattice comment have some problem. So, any helpful comment is highly appreciated.
Yours Sincerely,
Bahman
deposition simulation
#Phase 1 ------------------------------------------Simulation main setup----------------------------------
dimension 2
atom_style atomic
boundary p f p # in 2d models z shall be periodic
lattice sq2 2
#simulation box
region box block 0 105 0 105 -0.5 0.5 units box
create_box 3 box #2 is number of atoms
#particle
region particle cylinder z 52.5 52.5 20 -0.5 0.5 units box
create_atoms 1 region particle
group particle region particle
mass 1 63.546
#substrate
region substrate block 0 105 5 21 -0.5 0.5 units box
create_atoms 2 region substrate
group substrate region substrate
mass 2 63.546
#lower_substrate
region lower_substrate block 0 105 0 5 -0.5 0.5 units box
create_atoms 3 region lower_substrate
group lower_substrate region lower_substrate
mass 3 63.546
#–Phase 2----------------------------------------Lennard Jones Potential-----------------------------------------------
pair_style lj/cut 10
pair_coeff * * 3 2.3
neighbor 2.0 bin
neigh_modify delay 5
#neigh_modify delay 0 every 1 check yes
#----Phase 4-------------------------------------Initial Equilibration at 300K ----------------------------------------
reset_timestep 0
timestep 0.005 # Achtung! in metal unit time-step is by default 1 picoseconds scale
velocity all create 300 12345 mom yes rot no
fix 1 substrate setforce 0.0 0.0 0.0
fix 2 lower_substrate setforce 0.0 0.0 0.0
#fix 3 particle nvt temp 300.0 300.0 100.0
fix 3 particle nve
#thermo_modify lost ignore flush yes
thermo 100
dump 1 all xyz 100 dump.txt
run 3000
unfix 3
#----Phase 5---------------------------------------Particle Impact at the room temperature --------------------
velocity particle set 0 -5 0 # *100m/s
fix 4 particle nve
#fix 5 substrate temp/rescale 100 300.0 300.0 10.0 1.0
thermo 100
dump 2 all xyz 100 dump.txt
undump 2
run 8000
