"ERROR: Not all per-type masses are set" when using molecule command inserting TIP4P water molecule
There is a Ni0(H2O)2 molecule in box, the force field used for define it is UFF4MOF.
The data file is generated by lammps_interface and can run MD using lammps successfully.
Now I want to fill the box with TIP4P-Ew H2O molecules, and I use molecule and creat_atomscommand.
  1. The script run into an ERROR says "ERROR: Not all per-type masses are set". I’ve checked the input script carefully but can’t find out why, please help me.
  2. How to define the interaction between TIP4P-Ew H2O molecules and Ni0(H2O)2 since they are defined in different force field?
I am using lammps-11Aug17 and below is my input script.
Thanks a lot!
Zhongming
#content: in.H2O2-Ni0
log             log.H2O2-Ni0 append
units           real
atom_style      full
boundary        p p p
pair_style      hybrid lj/cut/coul/long 12.500 lj/cut/tip4p/long 9 10 9 16 0.1250 12.500 10.000
bond_style      harmonic
angle_style     hybrid fourier cosine/periodic harmonic
kspace_style    ewald 0.000001
dielectric      1.0
pair_modify     pair lj/cut/coul/long tail yes mix arithmetic
special_bonds   lj/coul 0.0 0.0 1.0
box tilt        large
read_data       data.H2O2-Ni0 extra/atom/types 2 extra/bond/types 1 extra/angle/types 1
# insert TIP4P-Ew H2O
molecule h2o H2O.txt offset 3 2 3 0 0
create_atoms 0 random 20 1 NULL mol h2o 1
# add coffs for TIP4P-Ew H2O according to http://lammps.sandia.gov/doc/Section_howto.html#tip4p-water-model
pair_coeff 4 4 lj/cut/tip4p/long 0.16275 3.16435
pair_coeff 4 5 lj/cut/tip4p/long 0.0 0.0
pair_coeff 5 5 lj/cut/tip4p/long 0.0 0.0
bond_coeff 3 559.995206 0.9572
angle_coeff 4 harmonic 300.0 104.52
dump myDump1 all atom 1 dump1.txt
velocity all create 298.0 12345689 dist uniform
neighbor 2.0 bin
neigh_modify delay 0 every 10 check yes
thermo      200
thermo_style custom step time temp
thermo_modify norm no flush yes
fix 1 all nvt temp 298.0 298.0 100.0
minimize 1.0e-8 1.0e-8 10000 10000
# output trj
dump trj2 all xyz 4000 MD-result.xyz
dump_modify trj2 element Zr C O O H Ni O H
timestep 0.5
run 200000 # run md for 0.1ns
# content: data.H2O2-Ni0
Created on Sat Mar 10 15:52:15 2018
           7 atoms
           6 bonds
           7 angles
           3 atom types
           2 bond types
           3 angle types
           0.000000  30.000000 xlo xhi
           0.000000  30.000000 ylo yhi
           0.000000  30.000000 zlo zhi
           0.000000   0.000000   0.000000 xy xz yz
Masses
    1    58.693400000 # Ni1
    2    15.999400000 # O_3
    3     1.007940000 # H_
Bond Coeffs
    1      272.490300        1.895541  # Ni1 O_3
    2      559.995206        0.990254  # O_3 H_
Angle Coeffs
    1              cosine/periodic       17.945113               1               1 # O_3 Ni1 O_3
    2                      fourier       57.090081        0.300235        0.267331        0.266745 # Ni1 O_3 H_
    3                      fourier      122.883342        0.300235        0.267331        0.266745 # H_ O_3 H_
Pair Coeffs
    1     lj/cut/coul/long   0.015000        2.524807 # Ni1 Ni1
    2     lj/cut/coul/long   0.060000        3.118146 # O_3 O_3
    3     lj/cut/coul/long   0.044000        2.571134 # H_ H_
Atoms
       1        1        1     0.00000   -6.51360   -3.19770    5.43240
       2        1        2     0.00000   -8.00880   -3.22170    6.57150
       3        1        3     0.00000   -7.67370   -3.33060    7.48860
       4        1        3     0.00000   -8.50470   -4.04940    6.38790
       5        1        2     0.00000   -5.04570   -3.16620    4.25970
       6        1        3     0.00000   -4.88910   -2.22900    4.01040
       7        1        3     0.00000   -4.25640   -3.42000    4.78620
Bonds
       1        1        1        2
       2        1        1        5
       3        2        2        3
       4        2        2        4
       5        2        5        6
       6        2        5        7
Angles
       1        1        2        1        5
       2        2        1        2        3
       3        3        3        2        4
       4        2        1        2        4
       5        2        1        5        6
       6        3        6        5        7
       7        2        1        5        7
# content: H2O.txt
Created on Sat Mar 10 09:43:39 2018
           3 atoms
           2 bonds
           1 angles
Coords
       1        8.17610    0.16360    0.10430 # O
       2        8.85210    0.64630    0.64340 # H
       3        7.32070    0.61450    0.31730 # H
Types
       1 1
       2 2
       3 2
Masses
    1    15.9994 # O
    2     1.008 # H
    3     1.008 # H
Charges
    1   -1.0484
    2   0.5242
    3   0.5242
Bonds
       1        1        1        2
       2        1        1        3
Angles
       1        1        2        1        3
# content :  log.lammps
units           real
atom_style      full
boundary        p p p
# for lj/cut/tip4p: LJ cutoff >= Coulomb cutoff + 2*(OM distance)
bond_style      harmonic
dielectric      1.0
box tilt        large
  triclinic box = (0 0 0) to (30 30 30) with tilt (0 0 0)
  2 by 2 by 2 MPI processor grid
  reading atoms ...
  7 atoms
  scanning bonds ...
  2 = max bonds/atom
  scanning angles ...
  3 = max angles/atom
  reading bonds ...
  6 bonds
  reading angles ...
  7 angles
  3 = max # of 1-2 neighbors
  4 = max # of 1-3 neighbors
  6 = max # of special neighbors
#### Atom Groupings ####
group           1        id   1:7
7 atoms in group 1
#### END Atom Groupings ####
# insert H2O
Read molecule h2o:
  3 atoms with 5 types
  2 bonds with 3 types
  1 angles with 4 types
  0 dihedrals with 0 types
  0 impropers with 0 types
WARNING: Molecule attributes do not match system attributes (../molecule.cpp:1369)
Created 60 atoms
# add coffs for h2o according to http://lammps.sandia.gov/doc/Section_howto.html#tip4p-water-model
ERROR: Not all per-type masses are set (../velocity.cpp:63)
Last command: velocity all create 298.0 12345689 dist uniform
in.H2O2-Ni0 (1.5 KB)
data.H2O2-Ni0 (2.09 KB)
H2O.txt (558 Bytes)
log.H2O2-Ni0 (1.83 KB)
UFF4MOF.
successfully.
me.
you are telling LAMMPS with the read_data command to reserve two
additional atom types. however, the data file will not contain their
masses and you don't set them anywhere. hence the error message.
this is a problem. you can try one of the mixing rules, but for the
most accurate result, you have to have parameters that are
consistently parameterized together.
p.s.: there is no need to use a hybrid pair style here, just using
lj/cut/tip4p/long is sufficient.
