I’d like to create a supercell using the lattice custom command. There are 144 basis atoms, so I created a file to store the coordinates of basis atoms, as shown in attached basis.cor. However, when I try to run the input script there is an error: ERROR: Input line too long: lattice custom 3.615 a1 -1 -1 2 a2 1 1 1 a3 -1 1 0 basis … I check the input.cpp and find that the MAXLINE is 2048, far larger than the 144. Below you will find part of the input script, and the basis.cor is also attached. Any suggestions or comments are highly appreciated!
#part of the input script
atom_style atomic
include basis.cor
region box block 0 9 0 9 0 9
#part of the basis.cor
lattice custom 3.615 a1 -1 -1 2 a2 1 1 1 a3 -1 1 0 &
basis 0 0 0.5 basis 0.125 0 0.25 basis 0.125 0 0.75 &
basis 0 0 0 basis 0.0416667 0.111111 0.25 basis 0.0416667 0.111111 0.75 &
basis 0.166667 0.111111 0.5 basis 0.166667 0.111111 0 basis 0.25 0 0 &
Junjie
