Hello everyone,
I am using LAMMPS to simulate wave propagation in an 1D
bead-spring chain with bond_harmonic potential, but after it reads my
data file, the following error message prints for 2 or greater number
of processors:
"Bond atoms 800 801 missing on proc 0 at step 0" (for two processors)
I would be grateful if someone could give me any advice.
My input file is listed as follows and its data file is attached.
Input script:
1D wave propagation
clear
units lj
dimension 2
boundary s p p
atom_style bond
bond_style harmonic
atom_modify map array sort 0 0.0
neighbor 2.0 nsq
read_data data.wave1d-noper
mass * 1.0
timestep 0.001
group source type 2
group other type 1
variable A equal 30.3
variable t0 equal 3.2
variable Zeta equal 2.0
variable xbef equal x[100]
variable xbef0 equal ${xbef}
variable xaft equal x[900]
variable xaft0 equal ${xaft}
variable xbedel equal x[100]-{xbef0} variable xafdel equal x[900]-{xaft0}
variable timer equal step*dt
thermo_style custom step
variable Lx equal -A*(step*dt-{t0})*exp(-{Zeta}*(step*dt-{t0})^2)
variable Ly equal 0.0
variable Lz equal 0.0
variable Vx equal A*(2*{Zeta}(stepdt-{t0})^2-1)*exp(-{Zeta}(stepdt-${t0})^2)
variable Vy equal 0.0
variable Vz equal 0.0
fix 1 other nve
fix 2 source move variable v_Lx v_Ly NULL v_Vx v_Vy NULL units box
fix PrintData all print 5 “{timer} {xbedel} ${xafdel}” file data.fourier
dump visualize all xyz 100 dump_wave1d_no-per.xyz
run 96000
With the Best Regards!
Zia Movaghar
data.wave1d-noper (92.2 KB)
