I managed to run it stably with NVE ensemble for 20ps in one simulation, and in NVT ensemble for 30ps in the other simulation.
Then I changed the ensemble to NPT and the simulation stopped due to pppm, out of range atoms errror.
I realise it’s hard to say in general, but do you think I gave my system enough time to equilibrate before running NPT?
I am trying to simulate bulk liquid (mixture of 360 heptane molecules and 40 glycerol monooleate molecules) under standard conditions.
What order of ensembles do you suggest for my purposes?
Are there any parameters in my input files that are worth looking into?
I realise it's hard to say in general, but do you think I gave my system
a few 10s of picoseconds it not much, particularly when your initial
system is far away from equilibrium.
sometimes it can also help to start with a minimization, if your initial
geometry has high potential energy.
it would be helpful to see some of your logs, e.g. the evolution of various
energies and particularly the pressure.
the PPPM out-of-range error happens most often with systems that expand or
shrink a lot. there are multiple possible reasons for that.
most common are: bad initial geometry, incorrect topology, bad/incorrect
force field parameters. typos etc.
it is usually best to determine good parameters with a simpler system,
i.e. two pure compounds, and then try the mixture later.
