I have been running simulations of a system of an interface of a Palmitic acid monolayer with water. I am using an OPLS force field. I was running with a timestep of 0.5 fs but I changed for a timestep of 2 fs and I constrained the C-H bonds and O-H bonds for the system to converge faster.
Here is some parameters:
pair_style lj/cut/tip4p/long 10 6 10 16 0.1546 8.5
pair_modify shift yes
bond_style harmonic
angle_style harmonic
dihedral_style opls
improper_style cvff
kspace_style pppm/tip4p 0.00001
special_bonds lj/coul 0.0 0.0 0.5
Everything worked fine but when I am trying to do the same with a system of Palmitate with water and Sodium ions (used as counterion). This error message appear after a certain time:
67210220 293.08927 -27320.486 -23285.127 339.14041 -515.10328 733.95842 798.56607 166.66195 -316.54275 -215.71227
67210240 300.78373 -27430.911 -23289.612 418.8136 -165.66854 440.11505 981.9943 248.66122 -160.85701 -285.41721
67210260 297.21773 -27373.697 -23281.496 -31.431348 -273.83507 -35.4121 214.95312 172.81895 -290.30868 -759.74581
67210280 352.2488 -26971.634 -22121.746 277.34245 172.24114 638.28525 21.500959 5.5087997 -171.32616 -228.80115
67210300 343.21135 -26809.168 -22083.71 65.124872 -289.03532 987.42832 -503.01839 212.1897 74.469053 300.96044
ERROR: Out of range atoms - cannot compute PPPM (…/pppm_tip4p.cpp:107)
So I read earlier posts about this kind of error and tried to play vith the kspace_style parameter and the neighbor parameter. But I still get the error message.
So my questions are:
Why does it work for the Palmitic acid but not for the Palmitate?
Why is the temperature (second column) raising just before crashing?
Is there something else I could try to fix this error without to have to reduce the timestep?
I hope that everything is clear and I gave enough information.
Raphael
