ERROR: Pair hybrid sub-style is not used
I am testing my input script for a system which I recently created. I have amorphous carbon (modeled as tersoff), interacting with a polymer through LJ interactions. I plan to use hybrid style for the simulations. Atomtypes 1-12 interact using lj/cut/coul/long + bonded interactions while atomtype 13 (amorphous carbon) is modeled with tersoff. The amorphous carbon/polymer interactions are to be modeled as lj/cut.
First, I switched tersoff potential to real units from metal by modifying the SiCGe.tersoff files and rescaling eV (A,B) parameters.
When I am trying to run following script, I am getting following error.
“Pair hybrid sub-style is not used”. In the below script, both sub-style are used. I am wondering if it needs to be done differently. Any guidance will be highly appreciated. Two related question?
  1. Do I need to specify the lj interactions specifically within 1 to 12 atom types explicitly as well when I use hybrid pairstyle.
  2. Do I need to specify the pair_style command before reading the file?
testout is the file which is being read. It has Pair Coeffs for 13 atom types. (13th pair coeff is just a dummy).
I got it to work (but have to check if that makes sense) after
  1. removing pair_coeffs from the data file,
  2. specifying pair_style none before reading the file.
  3. specifying pair_style hybrid tersoff lj/cut/coul/long 12 12 (after reading the file)
  4. removing pair_coeff * * lj/cut/coul/long 12 12 line
  5. Adding all possible combinations of pair_coeffs (total 90) seperately.
Is there a better way to do this.
Best Regards,
Vikas
"Pair hybrid sub-style is not used". In the below script, both sub-style are
no. mixing rules will be applied, if mixing is supported by a pair style.
if it contains a PairCoeff segment, yes. if not, no.
reading the file)
yes. put pair_style hybrid *before* reading the data file
keep your PairCoeff statements but prefix epsilon and sigma with
lj/cut and use "none" for type 13
then *after* reading the data file add the missing pair_coeff lines
including tersoff.
that should pretty much do what you wanted initially.
