Dear All,
I am using LAMMPS version 7Aug2019.
I have used the group/group command to calculate the energy transfer between water (TIP4P model) and gold (with no charge) from the following command:
compute pair water group/group Au pair yes
compute kspace water group/group Au pair no kspace yes
I have implemented the following pair style and LAMMPS has been stopped due to error.
pair_style lj/cut/tip4p/long 2 1 1 1 0.1546 10 8.5
pair_coeff 1 1 0.00 0.00
pair_coeff 2 2 0.18 3.15
pair_coeff 1 2 0.00 0.0
pair_coeff 3 3 5.0 2.9
pair_coeff 1 3 0.0 0.0
pair_coeff 2 3 1.0 3.6
The error is as follows:
ERROR: Pair style does not support compute group/group (…/compute_group_group.cpp:129)
As I have changed the pair style to a hybrid one as follows, the problem has been solved and the error did not appear anymore.
pair_style hybrid lj/cut/tip4p/long 2 1 1 1 0.1546 10 8.5 lj/cut 10
pair_coeff 1 1 lj/cut/tip4p/long 0.0 0.0
pair_coeff 2 2 lj/cut/tip4p/long 0.18 3.15
pair_coeff 1 2 lj/cut/tip4p/long 0.0 0.0
pair_coeff 3 3 lj/cut 5.0 2.9
pair_coeff 1 3 lj/cut 0.0 0.0
pair_coeff 2 3 lj/cut 1.0 3.6
Since I want to use “lj/cut/tip4p/long” for all interactions in the simulation, I will be pleased if someone can help me with this matter.
Is there any way to solve that?
Atom type 1 is Hydrogen, 2 is Oxygen and 3 is gold.
Best Regards,
Hamid
