Error related to airebo force field
Your first create a box with 1 atom type, where’s you pair coeff command assumes you have 2 (I.e., just lose de NULL).
Kristof
You have only one pair_style (I.e. not a hybrid style) so you don’t need the “airebo” in the pair_coeff command. Just drop that In addition to Kristof’s suggestion.
Ray
thank you for the solution and it worked.
I would like to use a hybrid pair_style for Carbon and Nickel interaction using airebo for (C-C), Ni.adp for (Ni - Ni) and lj/class2 for Ni - C.
However I get an ERROR: All pair coeffs are not set (…/pair.cpp:207)
My code is
pair_style hybrid airebo 3.0 adp lj/class2 10.0
pair_coeff * * airebo CH.airebo NULL C
pair_coeff * * adp Ni.adp NULL Ni
pair_coeff 1 2 lj/class2 2.0 1.4
Awaiting your valuable suggestions.
Shouvik
However I get an ERROR: All pair coeffs are not set (../pair.cpp:207)
My code is
just look at your pair_coeff commands!
you are assigning type 2 interactions twice and type 1 never.
Hello everybody,
thanks for the inputs. I have corrected my input file. The code works when I define Diamond and Nickel lattices in the input file.
However if I provide a data file for the diamond and define the Nickel lattice in the input file then I get an error as
Incorrect args for pair_coeff (…/pair_airebo.cpp:169). I cant seem to find the difference as the same pair coeff works when I define the diamond lattice in the input file.
Shouvik
read_data diamond-data.initial
region whole block 0 50 0 50 0 100 units box
#Ni atoms
lattice fcc 3.52
mass 1 28
create_atoms 1 random 100 12345 whole
Diamond potential
pair_style hybrid airebo 3.0 adp lj/cut 10
pair_coeff * * airebo CH.airebo C NULL
#Ni potential
pair_style lj/cut 10
pair_coeff 1 2 0.1034 2
Hello everybody,
Incorrect args for pair_coeff (../pair_airebo.cpp:169). I cant seem to find
most likely, the data file sets the total number of atom types to 1
instead of 2.
this is one of the properties in LAMMPS that cannot be changed after
the simulation box is defined, and that happens when reading a data
file.
