ERROR: Temperature compute degrees of freedom < 0
I am using granular package in conjunction with the fix rigid for simulation of non-spherical particles. I am simulating simple shear flow with the following (simplified) input script (initial data file attached)
atom_style sphere
newton off
comm_modify mode single vel yes
fix addMolecule all property/atom mol ghost yes
read_data init.dat fix addMolecule NULL Molecules #Initial particle cluster attached
set atom * mass 0.5
set atom * diameter 1.0
pair_style gran/hooke/history 10000 NULL 100 NULL 0.5 1
pair_coeff * *
timestep 0.001
fix 1 all rigid molecule
change_box all triclinic
compute biasTemp all temp/profile 1 0 0 y 10
compute sphTemp all temp/sphere bias biasTemp
thermo_style custom c_sphTemp
fix shearRun all deform 1 xy erate 0.05 remap v
run 100
the script works fine with older version of lammps (9Dec2014) and results seem reasonable, however I recently updated to 7Dec2015 to rerun some simulations and I get the following error:
ERROR: Temperature compute degrees of freedom < 0 (…/compute_temp_profile.cpp:248)
The problem seems to stem from a new line testing for (dof<0) and there seems to be slight changes to the way dof_compute() works (additional term d*Nbins subtracted)
I am just wondering if the developer can shed some lights on this issue.
Many thanks
sina
init.dat (313 KB)
  atom_style sphere
  newton off
cluster attached
  set atom * mass 0.5
  pair_coeff * *
  timestep 0.001
  run 100
(../compute_temp_profile.cpp:248)
d*Nbins subtracted)
compute temp/profile doesn't account for the additional degrees of
freedom of extended particles. the error exit is likely the
consequence of improved handling of degrees of freedom elsewhere.
