Hi Chandra,
Please always reply to the mailing list as well.
Another question, USER-SMD package requires external library to be installed, have you installed the “Eigen library” ?
For more information, please take a look again at the installation manual for each package requirement.
http://lammps.sandia.gov/doc/Section_packages.html#user-smd
Dear Emanuel
Sorry I forgot to cc the mailing list.
Yes I did install the ‘eigen library’ for 'USER-SMD.
I followed the exact procedure mentioned in the manual.
Thank you for the help.
Chandra
Hi Chandra,
I guess it should work well.
Try ‘make clean-all’ and ‘make purge’ before hitting ‘make mpi’
Dear Imanuel
I did ‘make clean-all’ and ‘make purge’ and then ‘make mpi’.
However I am still getting this same error when I run user-smd example.
Chandras-MacBook-Pro:rubber_strip_pull CP$ lmp_mpi < rubber_strip_pull.lmp
LAMMPS (11 Aug 2017)
ERROR: Unknown atom style (…/atom.cpp:487)
Last command: atom_style smd
Chandra
Dear Imanuel
I did 'make clean-all' and 'make purge' and then 'make mpi'.
ERROR: Unknown atom style (../atom.cpp:487)
are you certain, that you are actually using the newly compiled executable?
i see you are not using an absolute path to the lmp_mpi executable,
but have it looked up via $PATH
so did you copy a previously compiled executable to a folder in $PATH?
Dear Axel
Thank you very much.
I just used the actual path to ‘lammps/src/lmp_mpi’ and it works.
Thank you so much again.
Chandra
