We have a number of LAMMPS scripts where we pass variable values through the command line, i.e.,
lammps_executable -var xposition -10 < lammps_input_file
In the newer version (September 2011), we noticed that we are now getting an error when we try to do this. Is this a bug? Has this been intentionally done for some reason? If it is not intentional, is there a way to correct this either in future versions or for individual users to modify LAMMPS to allow this? I wasn’t quite sure when this problem arose, since we haven’t updated our LAMMPS version in a while.
Thank you for your time,
Mark
[email protected]…1024…
command line, i.e.,
yes. this is a bug.
the modification is trivial and fairly obvious.
you need to change the iarg += 2; in line 108 of lammps.cpp
into an iarg += 3; as shown in the patch file below.
allow this? I wasn't quite sure when this problem arose, since we haven't
according to git blame, the change goes back to february 2011.
looks like there are not many people assigning negative values
to variables that also use an up-to-date lammps binary.
cheers,
diff --git a/src/lammps.cpp b/src/lammps.cpp
index 09b6a48..2aaf0ea 100644
--- a/src/lammps.cpp
+++ b/src/lammps.cpp
@@ -105,7 +105,7 @@ LAMMPS::LAMMPS(int narg, char **arg, MPI_Comm communicator)
} else if (strcmp(arg[iarg],"-var") == 0 ||
strcmp(arg[iarg],"-v") == 0) {
if (iarg+3 > narg) error->universe_all(FLERR,"Invalid
command-line argument");
- iarg += 2;
+ iarg += 3;
while (iarg < narg && arg[iarg][0] != '-') iarg++;
} else if (strcmp(arg[iarg],"-echo") == 0 ||
strcmp(arg[iarg],"-e") == 0) {
I'll post a patch for this today. There is a similar change needed
in input.cpp. This still won't work if there are multiple args to
the -var, each with a leading "-" sign. Probably need to make
the syntax require one arg enclosed in quotes.
