Hi Shoieb,
Obviously this is something that shouldn’t happen & so no reason you need to try to understand the Fortran error. If you can post your input file then I’ll look into this.
MoTe2_2atoms-gulp.gin (687 Bytes) Out_MoTe2_2atoms.text (28.6 KB)
Hi Julian,
Above are my input file and the output file that is being generated. Any suggestion will be largely helpful.
