I am running a simulation using peri/lps model. In the input script, I used ‘restart 10000 test.restart’ command to generate restart files. Then I used the following script to restart a previous simulation:
read_restart test.restart.20000
neighbor 0.0010 bin
fix 1 all nve
fix 21 bottom setforce 0.0 0.0 0.0
fix 2 all indent 1e17 sphere 0.0000 v_y 0.0000 0.0015 units box
fix 3 all ave/time 1 1 100 f_2 f_2[1] f_2[2] f_2[3] file indent.restart
timestep 1.0e-7
run 10000
When I execute this script, I got an error message:
ERROR: Pair peri requires an atom map, see atom_modify (…/pair_peri_lps.cpp:431)
I copy & paste all the neighbor, fix, and timestep settings from the original script. Because the manual said those information is not stored in the restart file. I have no clue what causes this error. Any suggestions will be appreciated.
'restart 10000 test.restart' command to generate restart files. Then I used
neighbor 0.0010 bin
fix 1 all nve
timestep 1.0e-7
run 10000
(../pair_peri_lps.cpp:431)
Thank you very much for the suggestion. Now I add 'atom_modify map array’ to the top of the restart script. Then the previous error message is gone. But the simulation cannot continue. After the simulation stuck at step 20000 (when the restart file is generated) for a while, it gives an error message saying: Too many neighbor bins.
I am sure that I can run the simulation to at least 30000 steps without any problem. I wonder why I got ’too many neighbor bins’ error when I restart from 20000 step?
please before posting questions about error messages, have a look at
this page (or the equivalent in the manual.pdf file corresponding to
the version of LAMMPS that you are using).
from 20000 step?
i don't have a crystal ball, so i don't know what is going on over
there. most likely your simulation is not running stable and generates
unphysical results.
i just made a test restarting a peri/lps run based on the input in
examples/peri/in.peri and this has no problem restarting.
