Error while including LAMMPS package - EXTRA-COMPUTE
Dear LAMMPS Users,
I’m using LAMMPS 23 June 2022 version. I’m trying to include EXTRA-COMPUTE package by traditional make pathway.
make yes-EXTRA-COMPUTE
As a result I got this
Installing package EXTRA-COMPUTE
but after doing
make mpi
I’m facing the below error:
Gathering installed package information (may take a little while)
make[1]: Entering directory '/home/akshay/lammps-23Jun2022/src'
Gathering git version information
make[1]: Leaving directory '/home/akshay/lammps-23Jun2022/src'
Compiling LAMMPS for machine mpi
make[1]: Entering directory '/home/akshay/lammps-23Jun2022/src/Obj_mpi'
make[1]: Leaving directory '/home/akshay/lammps-23Jun2022/src/Obj_mpi'
mpicxx -g -O3 -std=c++11  -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64    -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1    -c ../compute_ackland_atom.cpp
In file included from ../compute.h:17,
                 from ../compute_ackland_atom.h:23,
                 from ../compute_ackland_atom.cpp:21:
../pointers.h:27:10: fatal error: mpi.h: No such file or directory
   27 | #include <mpi.h>        // IWYU pragma: export
compilation terminated.
make[1]: *** [Makefile:114: compute_ackland_atom.o] Error 1
make: *** [Makefile:393: mpi] Error 2
I don’t understand what is happening here? I wanted to use the
compute gyration/shape command.
Thanks and Regrads
Akshay
Your MPI installation is missing the necessary header files. Most likely you forgot to install the corresponding development package and only installed the MPI runtime.
Dear Axel,
I installed mpi. But this time I’m facing a different issue while including “EXTRA-COMPUTE”.
mpicxx -g -O3 -std=c++11  -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64    -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1    -c ../compute_adf.cpp
mpicxx -g -O3 -std=c++11  -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64    -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1    -c ../compute_ave_sphere_atom.cpp
mpicxx -g -O3 -std=c++11  -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64    -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1    -c ../compute_basal_atom.cpp
mpicxx -g -O3 -std=c++11  -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64    -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1    -c ../compute_born_matrix.cpp
mpicxx -g -O3 -std=c++11  -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64    -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1    -c ../compute_cnp_atom.cpp
mpicxx -g -O3 -std=c++11  -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64    -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1    -c ../compute_entropy_atom.cpp
mpicxx -g -O3 -std=c++11  -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64    -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1    -c ../compute_gyration_shape_chunk.cpp
mpicxx -g -O3 -std=c++11  -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64    -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1    -c ../compute_gyration_shape.cpp
mpicxx -g -O3 -std=c++11  -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64    -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1    -c ../compute_hexorder_atom.cpp
mpicxx -g -O3 -std=c++11  -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64    -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1    -c ../compute_hma.cpp
mpicxx -g -O3 -std=c++11  -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64    -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1    -c ../compute_momentum.cpp
mpicxx -g -O3 -std=c++11  -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64    -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1    -c ../compute_msd_nongauss.cpp
mpicxx -g -O3 -std=c++11  -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64    -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1    -c ../compute_stress_cartesian.cpp
mpicxx -g -O3 -std=c++11  -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64    -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1    -c ../compute_stress_cylinder.cpp
mpicxx -g -O3 -std=c++11  -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64    -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1    -c ../compute_stress_mop.cpp
mpicxx -g -O3 -std=c++11  -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64    -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1    -c ../compute_stress_mop_profile.cpp
mpicxx -g -O3 -std=c++11  -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64    -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1    -c ../compute_stress_spherical.cpp
mpicxx -g -O3 -std=c++11  -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64    -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1    -c ../compute_temp_rotate.cpp
mpicxx -g -O3 -std=c++11  -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64    -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1    -c ../compute_ti.cpp
mpicxx -g -O3 -std=c++11  -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64    -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1    -c ../lammps.cpp
mpicxx -g -O3 -std=c++11  -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64    -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1    -c ../modify.cpp
ar -rc ../liblammps_mpi.a angle.o angle_deprecated.o angle_hybrid.o angle_zero.o arg_info.o atom.o atom_map.o atom_vec_atomic.o atom_vec_body.o atom_vec_charge.o atom_vec.o atom_vec_ellipsoid.o atom_vec_hybrid.o atom_vec_line.o atom_vec_sphere.o atom_vec_tri.o balance.o body.o bond.o bond_deprecated.o bond_hybrid.o bond_zero.o change_box.o citeme.o comm_brick.o comm.o comm_tiled.o compute_ackland_atom.o compute_adf.o compute_aggregate_atom.o compute_angle.o compute_angle_local.o compute_angmom_chunk.o compute_ave_sphere_atom.o compute_basal_atom.o compute_bond.o compute_bond_local.o compute_born_matrix.o compute_centro_atom.o compute_centroid_stress_atom.o compute_chunk_atom.o compute_chunk_spread_atom.o compute_cluster_atom.o compute_cna_atom.o compute_cnp_atom.o compute_com_chunk.o compute_com.o compute_coord_atom.o compute.o compute_deprecated.o compute_dihedral.o compute_dihedral_local.o compute_dipole_chunk.o compute_dipole.o compute_displace_atom.o compute_entropy_atom.o compute_erotate_sphere_atom.o compute_erotate_sphere.o compute_fragment_atom.o compute_global_atom.o compute_group_group.o compute_gyration_chunk.o compute_gyration.o compute_gyration_shape_chunk.o compute_gyration_shape.o compute_heat_flux.o compute_hexorder_atom.o compute_hma.o compute_improper.o compute_improper_local.o compute_inertia_chunk.o compute_ke_atom.o compute_ke.o compute_momentum.o compute_msd_chunk.o compute_msd.o compute_msd_nongauss.o compute_omega_chunk.o compute_orientorder_atom.o compute_pair.o compute_pair_local.o compute_pe_atom.o compute_pe.o compute_pressure.o compute_property_atom.o compute_property_chunk.o compute_property_local.o compute_rdf.o compute_reduce_chunk.o compute_reduce.o compute_reduce_region.o compute_slice.o compute_stress_atom.o compute_stress_cartesian.o compute_stress_cylinder.o compute_stress_mop.o compute_stress_mop_profile.o compute_stress_spherical.o compute_temp_chunk.o compute_temp_com.o compute_temp.o compute_temp_deform.o compute_temp_partial.o compute_temp_profile.o compute_temp_ramp.o compute_temp_region.o compute_temp_rotate.o compute_temp_sphere.o compute_ti.o compute_torque_chunk.o compute_vacf.o compute_vcm_chunk.o create_atoms.o create_bonds.o create_box.o delete_atoms.o delete_bonds.o deprecated.o dihedral.o dihedral_deprecated.o dihedral_hybrid.o dihedral_zero.o displace_atoms.o domain.o dump_atom.o dump_cfg.o dump.o dump_custom.o dump_deprecated.o dump_image.o dump_local.o dump_movie.o dump_xyz.o error.o finish.o fix_adapt.o fix_addforce.o fix_ave_atom.o fix_ave_chunk.o fix_ave_correlate.o fix_aveforce.o fix_ave_histo.o fix_ave_histo_weight.o fix_ave_time.o fix_balance.o fix_bond_history.o fix_box_relax.o fix.o fix_deform.o fix_deposit.o fix_deprecated.o fix_dt_reset.o fix_dummy.o fix_efield.o fix_enforce2d.o fix_evaporate.o fix_external.o fix_gravity.o fix_group.o fix_halt.o fix_heat.o fix_indent.o fix_langevin.o fix_lineforce.o fix_minimize.o fix_momentum.o fix_move.o fix_neigh_history.o fix_nh.o fix_nh_sphere.o fix_nph.o fix_nph_sphere.o fix_npt.o fix_npt_sphere.o fix_nve.o fix_nve_limit.o fix_nve_noforce.o fix_nve_sphere.o fix_nvt.o fix_nvt_sllod.o fix_nvt_sphere.o fix_planeforce.o fix_press_berendsen.o fix_print.o fix_property_atom.o fix_read_restart.o fix_recenter.o fix_respa.o fix_restrain.o fix_setforce.o fix_spring_chunk.o fix_spring.o fix_spring_self.o fix_store.o fix_store_force.o fix_store_local.o fix_store_state.o fix_temp_berendsen.o fix_temp_rescale.o fix_thermal_conductivity.o fix_update_special_bonds.o fix_vector.o fix_viscous.o fix_wall.o fix_wall_harmonic.o fix_wall_lj1043.o fix_wall_lj126.o fix_wall_lj93.o fix_wall_morse.o fix_wall_reflect.o fix_wall_region.o fmtlib_format.o fmtlib_os.o force.o gridcomm.o group.o hashlittle.o image.o imbalance.o imbalance_group.o imbalance_neigh.o imbalance_store.o imbalance_time.o imbalance_var.o improper.o improper_deprecated.o improper_hybrid.o improper_zero.o info.o input.o integrate.o irregular.o kspace.o kspace_deprecated.o lammps.o lattice.o library.o lmppython.o math_eigen.o math_extra.o math_special.o memory.o min_cg.o min.o min_fire.o min_fire_old.o min_hftn.o minimize.o min_linesearch.o min_quickmin.o min_sd.o modify.o molecule.o my_page.o my_pool_chunk.o nbin.o nbin_multi.o nbin_standard.o neighbor.o neigh_list.o neigh_request.o npair_copy.o npair.o npair_full_bin_atomonly.o npair_full_bin.o npair_full_bin_ghost.o npair_full_multi.o npair_full_multi_old.o npair_full_nsq.o npair_full_nsq_ghost.o npair_half_bin_atomonly_newton.o npair_half_bin_newtoff.o npair_half_bin_newtoff_ghost.o npair_half_bin_newton.o npair_half_bin_newton_tri.o npair_halffull_newtoff.o npair_halffull_newton.o npair_half_multi_newtoff.o npair_half_multi_newton.o npair_half_multi_newton_tri.o npair_half_multi_old_newtoff.o npair_half_multi_old_newton.o npair_half_multi_old_newton_tri.o npair_half_nsq_newtoff.o npair_half_nsq_newtoff_ghost.o npair_half_nsq_newton.o npair_half_respa_bin_newtoff.o npair_half_respa_bin_newton.o npair_half_respa_bin_newton_tri.o npair_half_respa_nsq_newtoff.o npair_half_respa_nsq_newton.o npair_half_size_bin_newtoff.o npair_half_size_bin_newton.o npair_half_size_bin_newton_tri.o npair_half_size_multi_newtoff.o npair_half_size_multi_newton.o npair_half_size_multi_newton_tri.o npair_half_size_multi_old_newtoff.o npair_half_size_multi_old_newton.o npair_half_size_multi_old_newton_tri.o npair_half_size_nsq_newtoff.o npair_half_size_nsq_newton.o npair_skip.o npair_skip_respa.o npair_skip_size.o npair_skip_size_off2on.o npair_skip_size_off2on_oneside.o nstencil.o nstencil_full_bin_2d.o nstencil_full_bin_3d.o nstencil_full_ghost_bin_2d.o nstencil_full_ghost_bin_3d.o nstencil_full_multi_2d.o nstencil_full_multi_3d.o nstencil_full_multi_old_2d.o nstencil_full_multi_old_3d.o nstencil_half_bin_2d.o nstencil_half_bin_2d_tri.o nstencil_half_bin_3d.o nstencil_half_bin_3d_tri.o nstencil_half_multi_2d.o nstencil_half_multi_2d_tri.o nstencil_half_multi_3d.o nstencil_half_multi_3d_tri.o nstencil_half_multi_old_2d.o nstencil_half_multi_old_2d_tri.o nstencil_half_multi_old_3d.o nstencil_half_multi_old_3d_tri.o ntopo_angle_all.o ntopo_angle_partial.o ntopo_angle_template.o ntopo_bond_all.o ntopo_bond_partial.o ntopo_bond_template.o ntopo.o ntopo_dihedral_all.o ntopo_dihedral_partial.o ntopo_dihedral_template.o ntopo_improper_all.o ntopo_improper_partial.o ntopo_improper_template.o output.o pair_born.o pair_buck_coul_cut.o pair_buck.o pair_coul_cut.o pair_coul_debye.o pair_coul_dsf.o pair_coul_wolf.o pair.o pair_deprecated.o pair_hybrid.o pair_hybrid_overlay.o pair_hybrid_scaled.o pair_lj_cut_coul_cut.o pair_lj_cut.o pair_lj_expand.o pair_morse.o pair_soft.o pair_table.o pair_yukawa.o pair_zbl.o pair_zero.o platform.o potential_file_reader.o procmap.o random_mars.o random_park.o rcb.o read_data.o read_dump.o reader.o reader_native.o reader_xyz.o read_restart.o region_block.o region_cone.o region.o region_cylinder.o region_deprecated.o region_ellipsoid.o region_intersect.o region_plane.o region_prism.o region_sphere.o region_union.o replicate.o rerun.o reset_atom_ids.o reset_mol_ids.o respa.o run.o set.o special.o table_file_reader.o tabular_function.o text_file_reader.o thermo.o timer.o tokenizer.o universe.o update.o utils.o variable.o velocity.o verlet.o write_coeff.o write_data.o write_dump.o write_restart.o
mpicxx -g -O3 -std=c++11 main.o      -L. -llammps_mpi      -ldl  -o ../lmp_mpi
/usr/bin/ld: main.o: in function `main':
/data/lammps-stable/lammps-23Jun2022/src/Obj_mpi/../main.cpp:97: undefined reference to `LAMMPS_NS::LAMMPS::LAMMPS(int, char**, int)'
/usr/bin/ld: ./liblammps_mpi.a(lammps.o): in function `LAMMPS_NS::LAMMPS::LAMMPS(int, char**, ompi_communicator_t*)':
/home/akshay/lammps-23Jun2022/src/Obj_mpi/../lammps.cpp:127: undefined reference to `LAMMPS_NS::Universe::Universe(LAMMPS_NS::LAMMPS*, ompi_communicator_t*)'
/usr/bin/ld: /home/akshay/lammps-23Jun2022/src/Obj_mpi/../lammps.cpp:184: undefined reference to `LAMMPS_NS::Universe::Universe(LAMMPS_NS::LAMMPS*, ompi_communicator_t*)'
/usr/bin/ld: ./liblammps_mpi.a(library.o): in function `lammps_open':
/data/lammps-stable/lammps-23Jun2022/src/Obj_mpi/../library.cpp:186: undefined reference to `LAMMPS_NS::LAMMPS::LAMMPS(int, char**, int)'
/usr/bin/ld: ./liblammps_mpi.a(library.o): in function `lammps_open_no_mpi':
/usr/bin/ld: ./liblammps_mpi.a(library.o): in function `lammps_open_fortran':
collect2: error: ld returned 1 exit status
make[1]: *** [Makefile:94: ../lmp_mpi] Error 1
This looks like you have compile some of the objects with different options possibly from editing the makefile in between to address compilation issues.
Please try make clean-all and then make mpi again to see if it fails at the same spot.
It worked Axel. Thank you so much.
Out of curiosity, what did you mean by this?
So I included the EXTRA-COMPUTE package and ran my job. I stumble into this issue upon running it via parallel route.
LAMMPS (23 Jun 2022 - Update 1)
Reading data file ...
  orthogonal box = (0 0 0) to (158.5 158.5 100)
lmp_mpi: malloc.c:2617: sysmalloc: Assertion `(old_top == initial_top (av) && old_size == 0) || ((unsigned long) (old_size) >= MINSIZE && prev_inuse (old_top) && ((unsigned long) old_end & (pagesize - 1)) == 0)' failed.
[piano:673092] *** Process received signal ***
[piano:673092] Signal: Aborted (6)
[piano:673092] Signal code:  (-6)
[piano:673093] *** Process received signal ***
[piano:673093] Signal: Aborted (6)
[piano:673093] Signal code:  (-6)
[piano:673094] *** Process received signal ***
[piano:673094] Signal: Aborted (6)
[piano:673094] Signal code:  (-6)
[piano:673095] *** Process received signal ***
[piano:673095] Signal: Aborted (6)
[piano:673095] Signal code:  (-6)
[piano:673096] *** Process received signal ***
[piano:673096] Signal: Aborted (6)
[piano:673096] Signal code:  (-6)
[piano:673097] *** Process received signal ***
[piano:673097] Signal: Aborted (6)
[piano:673097] Signal code:  (-6)
[piano:673098] *** Process received signal ***
[piano:673098] Signal: Aborted (6)
[piano:673098] Signal code:  (-6)
[piano:673099] *** Process received signal ***
[piano:673099] Signal: Aborted (6)
[piano:673099] Signal code:  (-6)
[piano:673092] [ 0] [piano:673093] [ 0] [piano:673094] [ 0] [piano:673095] [ 0] [piano:673096] [ 0] [piano:673098] [ 0] [piano:673099] [ 0] [piano:673097] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7f8f9ac42520]
[piano:673098] [ 1] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7fb4d5242520]
[piano:673092] [ 1] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7fa6af642520]
[piano:673093] [ 1] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7fcb7b842520]
[piano:673094] [ 1] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7f55f1042520]
[piano:673095] [ 1] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7f5b7ae42520]
[piano:673099] [ 1] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7fdc18642520]
[piano:673096] [ 1] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7f73efc42520]
[piano:673097] [ 1] /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7fdc18696a7c]
[piano:673096] [ 2] /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7fa6af696a7c]
[piano:673093] [ 2] /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7f5b7ae96a7c]
[piano:673099] [ 2] /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7f73efc96a7c]
[piano:673097] [ 2] /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7f8f9ac96a7c]
[piano:673098] [ 2] /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7fb4d5296a7c]
[piano:673092] [ 2] /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7fcb7b896a7c]
[piano:673094] [ 2] /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7f55f1096a7c]
[piano:673095] [ 2] /lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7f5b7ae42476]
[piano:673099] [ 3] /lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7f73efc42476]
[piano:673097] [ 3] /lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7f8f9ac42476]
[piano:673098] [ 3] /lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7fdc18642476]
[piano:673096] [ 3] /lib/x86_64-linux-gnu/libc.so.6(abort+0xd3)[0x7fdc186287f3]
[piano:673096] [ 4] /lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7fb4d5242476]
[piano:673092] [ 3] /lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7fcb7b842476]
[piano:673094] [ 3] /lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7fa6af642476]
[piano:673093] [ 3] /lib/x86_64-linux-gnu/libc.so.6(abort+0xd3)[0x7fa6af6287f3]
[piano:673093] [ 4] /lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7f55f1042476]
[piano:673095] [ 3] /lib/x86_64-linux-gnu/libc.so.6(+0xa0f4a)[0x7fa6af6a0f4a]
[piano:673093] [ 5] /lib/x86_64-linux-gnu/libc.so.6(abort+0xd3)[0x7f5b7ae287f3]
[piano:673099] [ 4] /lib/x86_64-linux-gnu/libc.so.6(abort+0xd3)[0x7f73efc287f3]
[piano:673097] [ 4] /lib/x86_64-linux-gnu/libc.so.6(abort+0xd3)[0x7f8f9ac287f3]
[piano:673098] [ 4] /lib/x86_64-linux-gnu/libc.so.6(+0xa0f4a)[0x7fdc186a0f4a]
[piano:673096] [ 5] /lib/x86_64-linux-gnu/libc.so.6(abort+0xd3)[0x7fb4d52287f3]
[piano:673092] [ 4] /lib/x86_64-linux-gnu/libc.so.6(abort+0xd3)[0x7fcb7b8287f3]
[piano:673094] [ 4] /lib/x86_64-linux-gnu/libc.so.6(abort+0xd3)[0x7f55f10287f3]
[piano:673095] [ 4] /lib/x86_64-linux-gnu/libc.so.6(+0xa39b7)[0x7fdc186a39b7]
[piano:673096] [ 6] /lib/x86_64-linux-gnu/libc.so.6(+0xa0f4a)[0x7fcb7b8a0f4a]
[piano:673094] [ 5] /lib/x86_64-linux-gnu/libc.so.6(+0xa39b7)[0x7fa6af6a39b7]
[piano:673093] [ 6] /lib/x86_64-linux-gnu/libc.so.6(+0xa495d)[0x7fa6af6a495d]
[piano:673093] [ 7] /lib/x86_64-linux-gnu/libc.so.6(+0xa0f4a)[0x7f5b7aea0f4a]
[piano:673099] [ 5] /lib/x86_64-linux-gnu/libc.so.6(+0xa0f4a)[0x7f73efca0f4a]
[piano:673097] [ 5] /lib/x86_64-linux-gnu/libc.so.6(+0xa0f4a)[0x7f8f9aca0f4a]
[piano:673098] [ 5] /lib/x86_64-linux-gnu/libc.so.6(+0xa0f4a)[0x7f55f10a0f4a]
[piano:673095] [ 5] /lib/x86_64-linux-gnu/libc.so.6(+0xa0f4a)[0x7fb4d52a0f4a]
[piano:673092] [ 5] /lib/x86_64-linux-gnu/libc.so.6(+0xa495d)[0x7fdc186a495d]
[piano:673096] [ 7] /lib/x86_64-linux-gnu/libc.so.6(malloc+0x99)[0x7fdc186a51b9]
[piano:673096] [ 8] /lib/x86_64-linux-gnu/libc.so.6(+0xa39b7)[0x7fcb7b8a39b7]
[piano:673094] [ 6] /lib/x86_64-linux-gnu/libc.so.6(malloc+0x99)[0x7fa6af6a51b9]
[piano:673093] [ 8] /lib/x86_64-linux-gnu/libc.so.6(+0xa39b7)[0x7f5b7aea39b7]
[piano:673099] [ 6] /lib/x86_64-linux-gnu/libc.so.6(+0xa39b7)[0x7f73efca39b7]
[piano:673097] [ 6] /lib/x86_64-linux-gnu/libc.so.6(+0xa495d)[0x7f73efca495d]
[piano:673097] [ 7] /lib/x86_64-linux-gnu/libc.so.6(+0xa39b7)[0x7fb4d52a39b7]
[piano:673092] [ 6] /lib/x86_64-linux-gnu/libc.so.6(+0xa495d)[0x7fb4d52a495d]
[piano:673092] [ 7] /lib/x86_64-linux-gnu/libc.so.6(malloc+0x99)[0x7fb4d52a51b9]
[piano:673092] [ 8] /usr/local/lib/libmpi.so.40(+0x9f836)[0x7fdc18d39836]
[piano:673096] [ 9] /usr/local/lib/libmpi.so.40(mca_coll_base_comm_select+0x76)[0x7fdc18d39bd6]
[piano:673096] [10] /usr/local/lib/libmpi.so.40(+0x3827e)[0x7fdc18cd227e]
[piano:673096] [11] /usr/local/lib/libmpi.so.40(+0x3c3ec)[0x7fdc18cd63ec]
[piano:673096] [12] /lib/x86_64-linux-gnu/libc.so.6(+0xa495d)[0x7fcb7b8a495d]
[piano:673094] [ 7] /lib/x86_64-linux-gnu/libc.so.6(malloc+0x99)[0x7fcb7b8a51b9]
[piano:673094] [ 8] /usr/local/lib/libmpi.so.40(+0x9f836)[0x7fa6afe4f836]
[piano:673093] [ 9] /usr/local/lib/libmpi.so.40(mca_coll_base_comm_select+0x76)[0x7fa6afe4fbd6]
[piano:673093] [10] /usr/local/lib/libmpi.so.40(+0x3827e)[0x7fa6afde827e]
[piano:673093] [11] /usr/local/lib/libmpi.so.40(+0x3c3ec)[0x7fa6afdec3ec]
[piano:673093] [12] /lib/x86_64-linux-gnu/libc.so.6(+0xa495d)[0x7f5b7aea495d]
[piano:673099] [ 7] /lib/x86_64-linux-gnu/libc.so.6(malloc+0x99)[0x7f5b7aea51b9]
[piano:673099] [ 8] /lib/x86_64-linux-gnu/libc.so.6(+0xa39b7)[0x7f8f9aca39b7]
[piano:673098] [ 6] /lib/x86_64-linux-gnu/libc.so.6(+0xa495d)[0x7f8f9aca495d]
[piano:673098] [ 7] /lib/x86_64-linux-gnu/libc.so.6(malloc+0x99)[0x7f8f9aca51b9]
[piano:673098] [ 8] /lib/x86_64-linux-gnu/libc.so.6(+0xa39b7)[0x7f55f10a39b7]
[piano:673095] [ 6] /lib/x86_64-linux-gnu/libc.so.6(+0xa495d)[0x7f55f10a495d]
[piano:673095] [ 7] /lib/x86_64-linux-gnu/libc.so.6(malloc+0x99)[0x7f55f10a51b9]
[piano:673095] [ 8] /lib/x86_64-linux-gnu/libc.so.6(malloc+0x99)[0x7f73efca51b9]
[piano:673097] [ 8] /usr/local/lib/libmpi.so.40(+0x9f836)[0x7f73f049c836]
[piano:673097] /usr/local/lib/libmpi.so.40(+0x9f836)[0x7fb4d59eb836]
[piano:673092] [ 9] /usr/local/lib/libmpi.so.40(+0x9f836)[0x7fcb7c063836]
[piano:673094] [ 9] /usr/local/lib/libmpi.so.40(+0x9f836)[0x7f5b7b544836]
[piano:673099] [ 9] [ 9] /usr/local/lib/libmpi.so.40(mca_coll_base_comm_select+0x76)[0x7f73f049cbd6]
[piano:673097] [10] /usr/local/lib/libmpi.so.40(+0x3827e)[0x7f73f043527e]
/usr/local/lib/libmpi.so.40(+0x9f836)[0x7f55f18a3836]
[piano:673095] [ 9] /usr/local/lib/libmpi.so.40(mca_coll_base_comm_select+0x76)[0x7f55f18a3bd6]
[piano:673095] [10] /usr/local/lib/libmpi.so.40(+0x3827e)[0x7f55f183c27e]
[piano:673095] /usr/local/lib/libmpi.so.40(mca_coll_base_comm_select+0x76)[0x7f5b7b544bd6]
[piano:673099] [10] /usr/local/lib/libmpi.so.40(+0x3827e)[0x7f5b7b4dd27e]
[piano:673099] [11] /usr/local/lib/libopen-pal.so.40(opal_progress+0x34)[0x7fdc18525994]
[piano:673096] [13] /usr/local/lib/libmpi.so.40(ompi_comm_activate+0x9d)[0x7fdc18cd5dad]
[piano:673096] [14] /usr/local/lib/libmpi.so.40(ompi_comm_enable+0x1db)[0x7fdc18cd148b]
[piano:673096] [15] /usr/local/lib/libmpi.so.40(mca_topo_base_cart_create+0x1e2)[0x7fdc18d7dba2]
[piano:673096] [16] /usr/local/lib/libmpi.so.40(mca_coll_base_comm_select+0x76)[0x7fb4d59ebbd6]
[piano:673092] [10] /usr/local/lib/libmpi.so.40(+0x3827e)[0x7fb4d598427e]
[piano:673092] [11] /usr/local/lib/libopen-pal.so.40(opal_progress+0x34)[0x7fa6af866994]
[piano:673093] [13] /usr/local/lib/libmpi.so.40(ompi_comm_activate+0x9d)[0x7fa6afdebdad]
[piano:673093] [14] /usr/local/lib/libmpi.so.40(ompi_comm_enable+0x1db)[0x7fa6afde748b]
[piano:673093] [15] /usr/local/lib/libmpi.so.40(mca_topo_base_cart_create+0x1e2)[0x7fa6afe93ba2]
[piano:673093] [16] /usr/local/lib/libmpi.so.40(mca_coll_base_comm_select+0x76)[0x7fcb7c063bd6]
[piano:673094] [10] /usr/local/lib/libmpi.so.40(+0x3827e)[0x7fcb7bffc27e]
[piano:673094] [11] /usr/local/lib/libmpi.so.40(+0x9f836)[0x7f8f9b444836]
[piano:673098] [ 9] /usr/local/lib/libmpi.so.40(mca_coll_base_comm_select+0x76)[0x7f8f9b444bd6]
[piano:673098] [10] /usr/local/lib/libmpi.so.40(+0x3827e)[0x7f8f9b3dd27e]
[piano:673098] [11] [piano:673097] [11] /usr/local/lib/libmpi.so.40(+0x3c3ec)[0x7f73f04393ec]
[piano:673097] [12] /usr/local/lib/libopen-pal.so.40(opal_progress+0x34)[0x7f73efe66994]
[piano:673097] [13] /usr/local/lib/libmpi.so.40(+0x3c3ec)[0x7f8f9b3e13ec]
[piano:673098] [12] /usr/local/lib/libopen-pal.so.40(opal_progress+0x34)[0x7f8f9ae66994]
[piano:673098] [13] [11] /usr/local/lib/libmpi.so.40(+0x3c3ec)[0x7f55f18403ec]
[piano:673095] [12] /usr/local/lib/libopen-pal.so.40(opal_progress+0x34)[0x7f55f1266994]
[piano:673095] [13] /usr/local/lib/libmpi.so.40(+0x3c3ec)[0x7f5b7b4e13ec]
[piano:673099] [12] /usr/local/lib/libopen-pal.so.40(opal_progress+0x34)[0x7f5b7ad25994]
[piano:673099] [13] /usr/local/lib/libmpi.so.40(ompi_comm_activate+0x9d)[0x7f5b7b4e0dad]
/usr/local/lib/libmpi.so.40(MPI_Cart_create+0xec)[0x7fdc18d06d4c]
[piano:673096] [17] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0x4b44cb)[0x55ed385154cb]
[piano:673096] [18] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0x241d6f)[0x55ed382a2d6f]
[piano:673096] [19] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0x168a3e)[0x55ed381c9a3e]
[piano:673096] [20] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xc8008)[0x55ed38129008]
[piano:673096] [21] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xc85fe)[0x55ed381295fe]
[piano:673096] [22] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xa2ef1)[0x55ed38103ef1]
[piano:673096] [23] /usr/local/lib/libmpi.so.40(+0x3c3ec)[0x7fb4d59883ec]
[piano:673092] [12] /usr/local/lib/libopen-pal.so.40(opal_progress+0x34)[0x7fb4d5464994]
[piano:673092] [13] /usr/local/lib/libmpi.so.40(ompi_comm_activate+0x9d)[0x7fb4d5987dad]
[piano:673092] [14] /usr/local/lib/libmpi.so.40(MPI_Cart_create+0xec)[0x7fa6afe1cd4c]
[piano:673093] [17] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0x4b44cb)[0x562f827544cb]
[piano:673093] [18] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0x241d6f)[0x562f824e1d6f]
[piano:673093] [19] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0x168a3e)[0x562f82408a3e]
[piano:673093] [20] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xc8008)[0x562f82368008]
[piano:673093] [21] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xc85fe)[0x562f823685fe]
[piano:673093] [22] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xa2ef1)[0x562f82342ef1]
[piano:673093] [23] /usr/local/lib/libmpi.so.40(+0x3c3ec)[0x7fcb7c0003ec]
[piano:673094] [12] /usr/local/lib/libopen-pal.so.40(opal_progress+0x34)[0x7fcb7ba66994]
[piano:673094] [13] /usr/local/lib/libmpi.so.40(ompi_comm_activate+0x9d)[0x7fcb7bfffdad]
[piano:673094] [14] /usr/local/lib/libmpi.so.40(ompi_comm_activate+0x9d)[0x7f73f0438dad]
[piano:673097] [14] /usr/local/lib/libmpi.so.40(ompi_comm_enable+0x1db)[0x7f73f043448b]
[piano:673097] [15] /usr/local/lib/libmpi.so.40(mca_topo_base_cart_create+0x1e2)[0x7f73f04e0ba2]
[piano:673097] [16] /usr/local/lib/libmpi.so.40(ompi_comm_activate+0x9d)[0x7f8f9b3e0dad]
[piano:673098] [14] /usr/local/lib/libmpi.so.40(ompi_comm_enable+0x1db)[0x7f8f9b3dc48b]
[piano:673098] [15] /usr/local/lib/libmpi.so.40(mca_topo_base_cart_create+0x1e2)[0x7f8f9b488ba2]
[piano:673098] [16] /usr/local/lib/libmpi.so.40(ompi_comm_activate+0x9d)[0x7f55f183fdad]
[piano:673095] [14] /usr/local/lib/libmpi.so.40(ompi_comm_enable+0x1db)[0x7f55f183b48b]
[piano:673095] [15] /usr/local/lib/libmpi.so.40(mca_topo_base_cart_create+0x1e2)[0x7f55f18e7ba2]
[piano:673095] [16] [piano:673099] [14] /usr/local/lib/libmpi.so.40(ompi_comm_enable+0x1db)[0x7f5b7b4dc48b]
[piano:673099] [15] /usr/local/lib/libmpi.so.40(mca_topo_base_cart_create+0x1e2)[0x7f5b7b588ba2]
[piano:673099] [16] /lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7fdc18629d90]
[piano:673096] [24] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7fdc18629e40]
[piano:673096] [25] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xa3f55)[0x55ed38104f55]
[piano:673096] *** End of error message ***
/usr/local/lib/libmpi.so.40(ompi_comm_enable+0x1db)[0x7fb4d598348b]
[piano:673092] [15] /usr/local/lib/libmpi.so.40(mca_topo_base_cart_create+0x1e2)[0x7fb4d5a2fba2]
[piano:673092] [16] /lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7fa6af629d90]
[piano:673093] [24] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7fa6af629e40]
[piano:673093] [25] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xa3f55)[0x562f82343f55]
[piano:673093] *** End of error message ***
/usr/local/lib/libmpi.so.40(ompi_comm_enable+0x1db)[0x7fcb7bffb48b]
[piano:673094] [15] /usr/local/lib/libmpi.so.40(mca_topo_base_cart_create+0x1e2)[0x7fcb7c0a7ba2]
[piano:673094] [16] /usr/local/lib/libmpi.so.40(MPI_Cart_create+0xec)[0x7f73f0469d4c]
[piano:673097] [17] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0x4b44cb)[0x560592bf34cb]
[piano:673097] [18] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0x241d6f)[0x560592980d6f]
[piano:673097] [19] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0x168a3e)[0x5605928a7a3e]
[piano:673097] [20] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xc8008)[0x560592807008]
[piano:673097] [21] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xc85fe)[0x5605928075fe]
[piano:673097] [22] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xa2ef1)[0x5605927e1ef1]
[piano:673097] [23] /usr/local/lib/libmpi.so.40(MPI_Cart_create+0xec)[0x7f8f9b411d4c]
[piano:673098] [17] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0x4b44cb)[0x5613b23734cb]
[piano:673098] [18] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0x241d6f)[0x5613b2100d6f]
[piano:673098] [19] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0x168a3e)[0x5613b2027a3e]
[piano:673098] [20] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xc8008)[0x5613b1f87008]
[piano:673098] [21] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xc85fe)[0x5613b1f875fe]
[piano:673098] [22] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xa2ef1)[0x5613b1f61ef1]
[piano:673098] [23] /usr/local/lib/libmpi.so.40(MPI_Cart_create+0xec)[0x7f55f1870d4c]
[piano:673095] [17] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0x4b44cb)[0x562d320e44cb]
[piano:673095] [18] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0x241d6f)[0x562d31e71d6f]
[piano:673095] [19] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0x168a3e)[0x562d31d98a3e]
[piano:673095] [20] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xc8008)[0x562d31cf8008]
[piano:673095] [21] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xc85fe)[0x562d31cf85fe]
[piano:673095] [22] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xa2ef1)[0x562d31cd2ef1]
[piano:673095] [23] /usr/local/lib/libmpi.so.40(MPI_Cart_create+0xec)[0x7f5b7b511d4c]
[piano:673099] [17] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0x4b44cb)[0x5589a71ef4cb]
[piano:673099] [18] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0x241d6f)[0x5589a6f7cd6f]
[piano:673099] [19] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0x168a3e)[0x5589a6ea3a3e]
[piano:673099] [20] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xc8008)[0x5589a6e03008]
[piano:673099] [21] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xc85fe)[0x5589a6e035fe]
[piano:673099] [22] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xa2ef1)[0x5589a6dddef1]
[piano:673099] [23] /usr/local/lib/libmpi.so.40(MPI_Cart_create+0xec)[0x7fb4d59b8d4c]
[piano:673092] [17] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0x4b44cb)[0x5587854c44cb]
[piano:673092] [18] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0x241d6f)[0x558785251d6f]
[piano:673092] [19] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0x168a3e)[0x558785178a3e]
[piano:673092] [20] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xc8008)[0x5587850d8008]
[piano:673092] [21] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xc85fe)[0x5587850d85fe]
[piano:673092] [22] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xa2ef1)[0x5587850b2ef1]
[piano:673092] [23] /lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7fb4d5229d90]
[piano:673092] [24] /usr/local/lib/libmpi.so.40(MPI_Cart_create+0xec)[0x7fcb7c030d4c]
[piano:673094] [17] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0x4b44cb)[0x55affe1c14cb]
[piano:673094] [18] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0x241d6f)[0x55affdf4ed6f]
[piano:673094] [19] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0x168a3e)[0x55affde75a3e]
[piano:673094] [20] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xc8008)[0x55affddd5008]
[piano:673094] [21] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xc85fe)[0x55affddd55fe]
[piano:673094] [22] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xa2ef1)[0x55affddafef1]
[piano:673094] [23] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7fb4d5229e40]
[piano:673092] [25] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xa3f55)[0x5587850b3f55]
[piano:673092] *** End of error message ***
/lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7f73efc29d90]
[piano:673097] [24] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7f73efc29e40]
[piano:673097] [25] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xa3f55)[0x5605927e2f55]
[piano:673097] *** End of error message ***
/lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7f8f9ac29d90]
[piano:673098] [24] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7f8f9ac29e40]
[piano:673098] [25] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xa3f55)[0x5613b1f62f55]
[piano:673098] *** End of error message ***
/lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7f55f1029d90]
[piano:673095] [24] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7f55f1029e40]
[piano:673095] [25] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xa3f55)[0x562d31cd3f55]
[piano:673095] *** End of error message ***
/lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7f5b7ae29d90]
[piano:673099] [24] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7f5b7ae29e40]
[piano:673099] [25] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xa3f55)[0x5589a6ddef55]
[piano:673099] *** End of error message ***
/lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7fcb7b829d90]
[piano:673094] [24] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7fcb7b829e40]
[piano:673094] [25] /home/akshay/lammps-23Jun2022/src/lmp_mpi(+0xa3f55)[0x55affddb0f55]
[piano:673094] *** End of error message ***
Primary job  terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun noticed that process rank 6 with PID 0 on node piano exited on signal 6 (Aborted).
P.S. This lammps script runs fine when I ran it in serial mode.
No Idea, you may be running out of memory, or your computer may be running too hot or you are using some feature that is corrupting your memory. Please note that you are using Update 1 for the stable release, this has reached update 4 now with quite a number of bugs fixed (Releases · lammps/lammps · GitHub)
