Hello All,
I am running a simple calculation to calculate the total energy using the meam potential for Fe. Calculations run perfectly if I use the potential provided with the LAMMPS code, however if I try to use the meam potential published in the following paper, https://doi.org/10.1103/PhysRevB.89.094102, I get the following error:
Reading potential file library.meam with DATE: 2012-06-29
ERROR: Keyword Fe in MEAM parameter file not recognized (…/pair_meam.cpp:695)
Last command: pair_coeff * * library.meam Fe PRB.094102.meam Fe
The meam potential file (PRB.094102.meam ) is in the working directory, and is as follows (provided by the authors):
Hello All,
(../pair_meam.cpp:695)
yes. please study the meam example bundled with LAMMPS and also very
carefully study the documentation of pair style meam.
when comparing the various .meam files, it should be *very* obvious,
that your PRB.094102.meam file has to be use *instead* of library.meam
as the *first* .meam file, and its comments also refer to a necessary
FeC.meam file, which will have to be the *second* .meam file.
