Hi Everyone,
I wrote an in.* file to define the topology of my lattice, a part of my
file is as follows:
Hi Everyone,
file is as follows:
Hi Everyone,
file is as follows:#################################################################
# 2D NiMn shear simulationunits lj
atom_style atomic
dimension 2
boundary p s pvariable a equal 1.0
variable b equal 0.8lattice custom 1.0 a1 a 0 0 a2 0 b 0 &
basis 0 0 0 basis 0.5 0.5 0.5 orient x a b 0
###################################################################but i got error msg: illegal lattice command. Can anyone give me
suggestions on correcting this error?
you don't seem to be using variables correctly.
you need to prefix them with a $ sign to expand them.
if i do that, your lattice command works just fine.
see the documentation for the variable command for more details.
Dear Axel,
Thanks for your answer.
but if i make my script simple (remove variable command) as
Dear Axel,
units lj
atom_style atomic
dimension 2
boundary p s plattice custom 1.0 a1 1.0 0 0 a2 0 0.8 0 &
basis 0 0 0 basis 0.5 0.5 0.5 orient x 1.0 0.8 0
###################################################################this still gives me the same error msg.
not for me. do you use a current version of LAMMPS?
