error with making on redsky
Hi All,
I am having a few issues installing lammps on redsky. First off, I was unable to load the last of the modules it specifies I load before making in the makefile.redsky header.
Error:
-sh-3.2$ module load libraries/fftw-2.1.5_openmpi-1.4.1_oobpr_intel-11.1-f064-c064
ModuleCmd_Load.c(200):ERROR:105: Unable to locate a modulefile for ‘libraries/fftw-2.1.5_openmpi-1.4.1_oobpr_intel-11.1-f064-c064’
Second, when making it is failing to create the following .d files
Makefile:124: angle_charmm.d: No such file or directory
Makefile:124: angle_cosine.d: No such file or directory
Makefile:124: angle_cosine_delta.d: No such file or directory
Makefile:124: angle_cosine_periodic.d: No such file or directory
Makefile:124: angle_cosine_squared.d: No such file or directory
Makefile:124: angle.d: No such file or directory
Makefile:124: angle_harmonic.d: No such file or directory
Makefile:124: angle_hybrid.d: No such file or directory
Makefile:124: angle_table.d: No such file or directory
Makefile:124: atom.d: No such file or directory
Makefile:124: atom_vec_angle.d: No such file or directory
Makefile:124: atom_vec_atomic.d: No such file or directory
Makefile:124: atom_vec_bond.d: No such file or directory
Makefile:124: atom_vec_charge.d: No such file or directory
Makefile:124: atom_vec.d: No such file or directory
Makefile:124: atom_vec_ellipsoid.d: No such file or directory
Makefile:124: atom_vec_full.d: No such file or directory
Makefile:124: atom_vec_hybrid.d: No such file or directory
Makefile:124: atom_vec_molecular.d: No such file or directory
Makefile:124: atom_vec_sphere.d: No such file or directory
Makefile:124: bond.d: No such file or directory
Makefile:124: bond_fene.d: No such file or directory
Makefile:124: bond_fene_expand.d: No such file or directory
Is this a result of the missing module or something else I am doing wrong? It is folly to even try to make it while missing said module? How do I change it such that this missing module is available?
Thanks for your time and assistance,
Sara Waters
New Mexico Tech grad student
You'll have to ask the sysadmins on RedSky about the module issue.
The other messages are not errors, they are just normal messages from
make as it builds those *.d dependency files.
