Dear LAMMPS users,
I just installed last stable version of LAMMPS from 30July2016. I compiled it with GPU and Voronoi packages. Compilation went smooth.
I tried an example that works with version 14May2016.
It is a simple example where I define a box of Fe atoms with ppp or ppf boundary conditions. After creation of the box and of atoms I proceed to the first invocation of Voronoi tessalation as follows:
INITIAL VORONOI TESSELATION
compute v1 all voronoi/atom occupation
compute r0 all reduce sum c_v1[1]
compute r1 all reduce sum c_v1[2]
thermo_style custom c_r0 c_r1
run 0
This works with version 14May2016. With version 30Jul2016, the simulation stops at this stage with the following error message:
r0 r1
ERROR on proc 0: Failed to allocate -4 bytes for array voronoi/atom:occvec (…/memory.cpp:56)
ERROR on proc 3: Failed to allocate -4 bytes for array voronoi/atom:occvec (…/memory.cpp:56)
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 3
Cuda driver error 4 in call at file ‘geryon/nvd_device.h’ in line 124.
application called MPI_Abort(MPI_COMM_WORLD, -1) - process 3
ERROR on proc 2: Failed to allocate -4 bytes for array voronoi/atom:occvec (…/memory.cpp:56)
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 2
ERROR on proc 1: Failed to allocate -4 bytes for array voronoi/atom:occvec (…/memory.cpp:56)
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 1
application called MPI_Abort(MPI_COMM_WORLD, -1) - process 2
Christophe
