Error
Dear lammps Users,
I have bad problem on running lammps code, I have water molecules with type 3 and 4 and my graphene sheet type is 2.
when I run code with “neigh_modify delay 0 every 1 check yes exclude type 2 2 exclude type 3 3 exclude type 2 3”, It gave me "Error: out of range of atom and pressure item goes NaN.
but when I removed “exclude type 3 3” from above and run again it has no error and run completely but when I saw simulation, water molecules penetrate into graphene sheet not across pore that it is not acceptable!
How I can run my project without removing “exclude type 3 3” ?
please help me.
Omid
Dear lammps Users,
Please tell us why an unphysical model should give physically meaningful results?
In other words, why on earth do you think you need to use those neighbor list tweaks?
Axel
