errore defining atom creation
I’m trying to insert argon atoms in a box with volume 1000 A at 87K
In the box I defined one Ar
This is my inputfile
I'm trying to insert argon atoms in a box with volume 1000 A at 87K
# TEST Ar 87K
# System
units real
atom_style full
newton on on
# Styles
pair_style lj/class2/coul/long 18.5
bond_style class2
angle_style class2
dihedral_style class2
improper_style class2
pair_modify tail no
kspace_style ewald 1.0e-07
# box, start molecules on simple cubic lattice
read_data box_10_Ar.data
#probe
molecule ar ./ar.txt
# rigid Ar model
pair_coeff 1 1 0.2000000000 3.8800000000
# masses
mass 1 39.944000
# region
region zone1 block 0 10 0 10 0 10 units box
# group
group group1 region zone1
#create atom
create_atoms 1 zone1 mol ar
# velocity
velocity group1 create 87 87 mom yes rot yes
# MD Settings
neighbor 4.0 bin
neigh_modify every 1 delay 10 check yes
timestep 1.0
# gcmc
thermo 1
compute_modify thermo_temp dynamic yes
variable density equal atoms/vol
fix 1 all gcmc 100 1000000 1000000 0 88891 87.0 0.0 1 mol ar
pressure 0.88 fugacity_coeff 0.90
thermo_style custom step temp press pe ke density vol atoms
run 10000000
I obtain this message error
ERROR: Illegal create_atoms command
How can I fix it?
​by using the correct syntax for create_atoms. yours is wrong, hence the
error.
also, please explain what is the point for using a molecule template for a
single atom?
you are just making your life needlessly complicated.
axel.​
# TEST Ar 87K
# System
units real
atom_style full
newton on on
# Styles
bond_style class2
angle_style class2
pair_modify tail no
#probe
# rigid Ar model
# masses
mass 1 39.944000
# region
# group
#create atom
# velocity
# MD Settings
neighbor 4.0 bin
timestep 1.0
# gcmc
thermo 1
run 10000000
How can I fix it?
error.
single atom?
axel.​
*What is the right syntax?*
*I wanted to test the mol key then apply it to three atomic systems.*
*​Al​*
How can I fix it?
error.
a single atom?
axel.​
LAMMPS Molecular Dynamics Simulator
