Dear users
I get errors as soon as I submit some jobs but not with others. The difference between the jobs may only be a change in number of atoms or a change in box dimension.
As far as I can see the input and data files are all correct. The errors give no indication of whats wrong. Whether a job runs or gives errors seems almost random!
See errors below:
FIRST ERROR TYPE:
Reading data file …
orthogonal box = (-1000 -1000 -0.7113) to (1000 1000 425.291)
6 by 6 by 1 processor grid
[r2i1n3:mpi_rank_1][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n3:mpi_rank_2][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n3:mpi_rank_3][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n3:mpi_rank_4][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n3:mpi_rank_5][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n3:mpi_rank_6][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n3:mpi_rank_7][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n3:mpi_rank_8][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n3:mpi_rank_9][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n3:mpi_rank_10][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n3:mpi_rank_11][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n3:mpi_rank_0][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n1:mpi_rank_12][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n1:mpi_rank_13][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n1:mpi_rank_14][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n1:mpi_rank_15][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n1:mpi_rank_16][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n1:mpi_rank_17][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n1:mpi_rank_22][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n1:mpi_rank_18][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n1:mpi_rank_19][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n1:mpi_rank_20][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n1:mpi_rank_21][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n1:mpi_rank_23][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n11:mpi_rank_24][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n11:mpi_rank_25][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n11:mpi_rank_26][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n11:mpi_rank_27][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n11:mpi_rank_28][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n11:mpi_rank_29][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n11:mpi_rank_30][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n11:mpi_rank_31][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n11:mpi_rank_32][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n11:mpi_rank_33][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n11:mpi_rank_34][error_sighandler] Caught error: Segmentation fault
(signal 11)
[r2i1n11:mpi_rank_35][error_sighandler] Caught error: Segmentation fault
(signal 11)
mpiexec_raw: Warning: tasks 0-35 died with signal 11 (Segmentation
fault).
SECOND ERROR TYPE:
ERROR on proc 0: Cannot open dump file
[cli_0]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
mpiexec_raw: Warning: task 0 exited with status 1.
mpiexec_raw: Warning: tasks 1-35 died with signal 15 (Terminated).
Thanks in advance,
Daniel
