Errors when compiling LAMMPS on CentOS 6.2 with OpenMPI
I am a very new user to Linux and compiling on my own cluster. I have attempted to install OpenMPI on my own and thereafter compile LAMMPS (21 Jan 2013). However I encountered errors which I simply could not resolve:
angle_charmm.o: In function Intracomm': /usr/include/openmpi-x86_64/openmpi/ompi/mpi/cxx/intracomm.h:25: undefined reference to MPI::Comm::Comm()’
/usr/include/openmpi-x86_64/openmpi/ompi/mpi/cxx/intracomm.h:25: undefined reference to MPI::Comm::Comm()' angle_charmm.o: In function Intracomm’:
/usr/include/openmpi-x86_64/openmpi/ompi/mpi/cxx/intracomm_inln.h:23: undefined reference to MPI::Comm::Comm()' angle_charmm.o: In function MPI::Op::Init(void ()(void const, void*, int, MPI::Datatype const&), bool)’:
/usr/include/openmpi-x86_64/openmpi/ompi/mpi/cxx/op_inln.h:122: undefined reference to ompi_mpi_cxx_op_intercept' angle_charmm.o: In function Intracomm’:
/usr/include/openmpi-x86_64/openmpi/ompi/mpi/cxx/intracomm.h:25: undefined reference to MPI::Comm::Comm()' /usr/include/openmpi-x86_64/openmpi/ompi/mpi/cxx/intracomm.h:25: undefined reference to MPI::Comm::Comm()’
/usr/include/openmpi-x86_64/openmpi/ompi/mpi/cxx/intracomm_inln.h:23: undefined reference to MPI::Comm::Comm()' /usr/include/openmpi-x86_64/openmpi/ompi/mpi/cxx/intracomm_inln.h:23: undefined reference to MPI::Comm::Comm()’
angle_charmm.o:/usr/include/openmpi-x86_64/openmpi/ompi/mpi/cxx/intracomm_inln.h:23: more undefined references to MPI::Comm::Comm()' follow angle_charmm.o:(.rodata._ZTVN3MPI3WinE[vtable for MPI::Win]+0x48): undefined reference to MPI::Win::Free()’
angle_charmm.o:(.rodata._ZTVN3MPI8DatatypeE[vtable for MPI::Datatype]+0x78): undefined reference to MPI::Datatype::Free()' collect2: ld returned 1 exit status make[1]: *** [../lmp_linux] Error 1 make[1]: Leaving directory /opt/lammps-21Jan13/src/Obj_linux’
make: *** [linux] Error 2
Does anyone have experience with this issue? Have I somehow installed OpenMPI wrongly or is this an issue with LAMMPS? I issued the commands:
make yes-standard no-GPU no-REAX no-POEMS no-MEAM no-KIM
My makefile settings are as below:
SHELL = /bin/sh
compiler/linker settings
specify flags and libraries needed for your compiler
CC = mpicc
CCFLAGS = -g -O
SHFLAGS = -fPIC
DEPFLAGS = -M
LINK = mpicc
LINKFLAGS = -O
LIB = -lstdc++
SIZE = size
ARCHIVE = ar
ARFLAGS = -rc
SHLIBFLAGS = -shared
LAMMPS-specific settings
specify settings for LAMMPS features you will use
if you change any -D setting, do full re-compile after “make clean”
LAMMPS ifdef settings, OPTIONAL
see possible settings in doc/Section_start.html#2_2 (step 4)
LMP_INC = -DLAMMPS_GZIP
MPI library, REQUIRED
see discussion in doc/Section_start.html#2_2 (step 5)
can point to dummy MPI library in src/STUBS as in Makefile.serial
INC = path for mpi.h, MPI compiler settings
PATH = path for MPI library
LIB = name of MPI library
MPI_INC = -DMPICH_IGNORE_CXX_SEEK
MPI_PATH =
MPI_LIB =
FFT library, OPTIONAL
see discussion in doc/Section_start.html#2_2 (step 6)
can be left blank to use provided KISS FFT library
INC = -DFFT setting, e.g. -DFFT_FFTW, FFT compiler settings
PATH = path for FFT library
LIB = name of FFT library
FFT_INC =
FFT_PATH =
FFT_LIB =
JPEG library, OPTIONAL
see discussion in doc/Section_start.html#2_2 (step 7)
only needed if -DLAMMPS_JPEG listed with LMP_INC
INC = path for jpeglib.h
PATH = path for JPEG library
LIB = name of JPEG library
JPG_INC =
JPG_PATH =
JPG_LIB =
I would be very grateful for any pointers with regards to this issue, thank you!
Regards,
Jingjie Yeo
Ph.D. Student
School of Mechanical and Aerospace Engineering
Nanyang Technological University, Singapore
please replace -DMPICH_IGNORE_CXX_SEEK (which is for MPICH)
with -DOMPI_SKIP_MPICXX=1 (which is the equivalent for OpenMPI).
you have to do a make clean-all since this affect inline functions.
once you get a working executable, you should try compiler
optimization to get a noticeable speed increase.
i have for CCFLAGS:
-O2 -fno-rtti -fno-exceptions -march=native -ffast-math -mpc64 \
-finline-functions -funroll-loops -fstrict-aliasing
good luck,
