Hi, try to calculate OFM from compouds’ structures in materials project.
almost structures are OK but some ones got errors.
for example:
mp_id: mp-623782
QH6214 qhull input error: not enough points(2) to construct initial simplex (need 5)
While executing: | qhull v Qz Qc Qbb
Options selected for Qhull 2015.2.r 2016/01/18:
run-id 1652223445 voronoi Qz-infinity-point Qcoplanar-keep Qbbound-last
_pre-merge _zero-centrum Qinterior-keep
This not the only one but all errors are similar.
Could you check it.
Thanks.
Thanks for reporting this problem!
I suspect what’s happening here is a problem in the Voronoi tessellation code used by OFM. Voronoi tessellations tend to fail for some crystal structures due to numerical issues inherent to Voronoi tessellations of high-symmetry structures. I typically see an error rate of a about 1% for crystalline materials.
I have opened an issue on Matminer that suggests we report better error messages, and a few ideas to help lower the error rate.
Logan
Sent: Wednesday, July 4, 2018 3:45 AM
To: matminer
Subject: Errors when use OrbitalFieldMatrix featuizer with materials projectdata
for example:
mp_id: mp-623782
Could you check it.
Thanks.
You received this message because you are subscribed to the Google Groups “matminer” group.
To unsubscribe from this group and stop receiving emails from it, send an email to [email protected].
To view this discussion on the web visit https://groups.google.com/d/msgid/matminer/6403ae54-3c89-4c4e-88de-be730b066861%40googlegroups.com.
For more options, visit https://groups.google.com/d/optout.
Thank you for your really quick reply. I will follow the issue.
Chang
在 2018年7月5日星期四 UTC+9上午12:49:34,Logan Ward写道:
Logan
To: matminer
for example:
mp_id: mp-623782
Could you check it.
Thanks.
Logan
To: matminer
for example:
mp_id: mp-623782
Could you check it.
Thanks.
