I am struggling to use EwaldSiteEnergy function. How can I get ‘charges that are already-defined for the structure’ on the notes? I would appreciate if you can provide some of example script.
Thanks in advance,
Sung Beom Cho
Thanks in advance,
Sung Beom Cho
One way you can get the charges on each site by first using the structure_to_oxidstructure
function in matminer’s utility functions (link).
The code would be something like
from matminer.utils.conversions import structure_to_oxidstructure
structure_to_oxidstructure(data[‘structure’], inplace=True)
This code will attempt to guess oxidation states for each atom based on the composition of the structure, and save that oxidation state in the structure so that EwaldSiteEnergy could use it.
If your data is not in a pandas DataFrame, you can call the add_oxidation_state_by_guess
function directly (see pymatgen’s documentation, and an example in matminer’s unit tests).
Logan
Sent: Wednesday, July 25, 2018 4:43 PM
To: matminer
Subject: Ewald featurization
Thanks in advance,
Sung Beom Cho
You received this message because you are subscribed to the Google Groups “matminer” group.
To unsubscribe from this group and stop receiving emails from it, send an email to [email protected].
To view this discussion on the web visit https://groups.google.com/d/msgid/matminer/91ad06a6-3aa7-4ff1-8ec4-987d685021eb%40googlegroups.com.
For more options, visit https://groups.google.com/d/optout.
Just a note that there are other ways also to get oxidation states including BVAnalyzer in pymatgen (bond valence method) if you are familiar with how to use pymatgen.
This notebook in matminer examples tells you how to use the default guessing strategy:
see section 2.2
Logan
To: matminer
Thanks in advance,
Sung Beom Cho
To view this discussion on the web visit https://groups.google.com/d/msgid/matminer/5b58f0c6.1c69fb81.77cbe.bee9%40mx.google.com.
Anubhav
Thank you very much. It solved.
2018년 7월 25일 수요일 오후 4시 43분 52초 UTC-5, 조성범 님의 말:
Thanks in advance,
Sung Beom Cho
