Ewald sum/PPPM accuracy
Dear LAMMPS users;
I have question about Ewald sum/PPPM long range solver for LAMMPS. Accuracy of Ewald sum depends on \alpha: rate of convergence parameter, r_cut: real space force cut off distance, and m_max: number of k_spaces. If this is correct how ewald_value/pppm_value connects to these parameters?
Many thanks,
Sahand
Dear LAMMPS users;
​please have a closer look at the documentation for the kspace_style
command. it references several papers and expressions that are used in
LAMMPS to estimate errors and accuracy. i would suggest to get hold of a
copy of those papers, study them, and if you still have doubts, consult the
relevant source code in kspace.cpp
axel.​
Thank you Axel.
