I am testing the thermal conductivity example in.langevin of KAPPA with some appropriate changes.
The details as follows:
I have defined lattice and region
lattice sc 1.20
region box block 0 10 0 10 0 50
Then heat layers
region hot block INF INF INF INF 0 5
region cold block INF INF INF INF 25 30
compute Thot all temp/region hot
compute Tcold all temp/region cold
Then I run for two million steps (default step length dt=0.005) with nvt at T=1.0
fix 1 all nvt temp 1.0 1.0 0.5
run 2000000
To establish the heat current between the heat layers, I thermostat the hot and cold regions through following fixes upto 5 milliion steps
fix 1 all nve
fix hot all langevin 1.05 1.05 1.0 59804 tally yes
fix cold all langevin 0.95 0.95 1.0 287859 tally yes
fix_modify hot temp Thot
fix_modify cold temp Tcold
run 5000000
Then I assume that steady state has been maintained and I start collecting data. Hence, I reset the fixes hot & cold and their modifies for further ten million steps.
fix ave all ave/time 5 100 500 v_tdiff ave running
thermo_style custom step temp c_Thot c_Tcold f_hot f_cold v_tdiff f_ave
run 10000000
I calculate the average of c_Thot and c_Tcold for the last 10 million steps. I expect the averages to be close to 1.05 and 0.95. But they come out to be 1.04038672 and 0.963709826.
Can anyone explain that why the average values are too far from expected values? And would you please suggest me that what can I do to get more precise averages.
N.B.- Any point which I have not mentioned in this mail, assume they are same as in the example in.langevin. I even tried this example with berendsen thermostat in place of langevin thermostat. In that case I get averages of Thot and Tcold little better but they are still far from 1.05 and 0.95.
Vinay vaibhav
PhD Student, Theoretical Physics
The Institute of Mathematical Sciences Chennai, India
lattice sc 1.20
Then heat layers
nvt at T=1.0
run 2000000
fix 1 all nve
run 5000000
run 10000000
you are doing a *non-equilibrium* simulation and a 1% deviation is not
that much for the choice of parameters. the averages *are* precise.
apart from that, why do you worry? for the computation of the thermal
conductivity you are to use the averaged *actual* temperatures anyway.
Hi Vinay,
For a local Langevin thermostat in nemd, I also noticed a small mismatch
between the specified target temperature and the nemd average of the
respective slab. From my experience this difference depends on the
choice of your damping parameter. Try using a smaller value for damp to
see if you get better agreement.
However, if you want to specify the temperature exactly, you might want
to consider temp/rescale, applied locally using dynamic groups, instead
of fix langevin. This basically corresponds to a local Gaussian
thermostat where you fix the kinetic energy exactly (apart from some
higher-order terms in dt).
Peter
Hi Vinay,
temp/rescale is a bad idea. it gives the group you thermostat a "kick"
every time it hits.
Hi
As Axel told, 1 percent error is not that much especially in MD which suffers from statistical uncertainties. The suggestions of Peter are very helpful.
I also suggest you to use “compute temp/region” for calculating the temperatures.
In fact, if you compare the results of the method used in in.langevin (“compute ke/atom” command) with “compute temp/region” command, you will notice that the result of the former is 1/Natoms*Temp smaller (which for a region of 100 atoms creates about 1% error). This is because the latter, by considering ”fix nve” as a constraint, reduces the degrees of freedom of the region by one which is not considered in in.langevin.
Or equivalently, you could multiply “variable temp” by Natoms and divide by (Ntoms-1) which is the real degrees of freedom.
Albeit I am not 1completely sure about the above statements. Therefore, any corrections will be appreciated.
regards
I should add:
Maybe the difference in the results of two commands is duo to three constraints imposed by conserving the linear momentum of the system along 3 coordinate axes. This causes the number of degrees of freedom (dof) to reduce by three. subtracting them from 3N means dof=3N-3=3(N-1) which looks like Natoms is reduced one.
Therefore, multiplying “variable temp” by Natoms then diving it by (Ntoms-1) would be equivalent to use “compute temp/region” command.
As per lammps documentation section 3.8, the pair style lj/smooth/linear cannot be accelerated using the GPU package. Currently, I am using this pair potential for my simulations using lammps with cpus.
Can anyone suggest me some way so that this pair potential could be accelerated using gpu?
How difficult it is to write pair_lj_smooth_linear_gpu.cpp and pair_lj_smooth_linear_gpu.h following the steps in pair_lj_cut_gpu.cpp and pair_lj_cut_gpu.h respectively?
With thanks and regards,
Vinay Vaibhav
Ph.D. Student, Theoretical Physics
you could try using the pair_write command to write out your potential
to a table file and then use the GPU accelerated table style.
that depends entirely on your programming abilities.
You could also write a Kokkos version of pair_lj_smooth_linear_gpu.cpp. There are several examples to follow such as /src/KOKKOS/pair_lj_cut_kokkos.cpp. You write the pair style in C++, and then Kokkos library will map it onto CUDA so it can run on GPUs.
Stan
Stan’s suggestion is super simple if you follow this document.
porting-pair-styles-to-kokkos.txt (13.5 KB)
