I’ve been over the LAMMPS web site and searched the web for an example or tutorial on how to set up a LAMMPS simulation of a solvated DNA system (starting with a pdb file) where all the residue, chain and sequence information (i.e. all the information in the ATOM/HETATM record) is retained in the output file. I have been unable to find such an example or tutorial.
I will be running the Kokkos GPU accelerated ReaxFF package.
Any help, tutorial links or examples would be appreciated.
Jim
James Kress Ph.D., President
The KressWorks® Institute
An IRS Approved 501 ©(3) Charitable, Nonprofit Corporation
“Engineering The Cure” ©
(248) 573-5499
Learn More and Donate At:
Website: http://www.kressworks.org
Facebook: https://www.facebook.com/KressWorks.Institute/
Twitter: @KressWorksFnd
So the tools/ch2lmp scripts will convert a PDB file to a LAMMPS data file.
It also adds all the CHARMM ff coeff info and bond/angle topologies.
If you are wanting to run with ReaxFF, can you just delete
that info from the data file, and have what you need?
Steve,
Thanks. I’ll give it a try and let the List know what happens.
Jim
(248) 573-5499
Confidentiality Notice | This e-mail message, including any attachments, is for the sole use of the intended recipient(s) and may contain confidential or proprietary information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, immediately contact the sender by reply e-mail and destroy all copies of the original message.
One other thing you probably already realize.
The LAMMPS data file will just have atom IDs, types,
molecule IDs (all integers).
So if this:
is text-based info like CHARMM atom types or residue
names, it will not be preserved by LAMMPS.
However, the ch2lmp tool also has a script which
converts LAMMPS dump snapshots back into CHARMM-
compatible files, PDB if I remember. That step may
re-associate the LAMMPS atom ID with the info in
the original PDB. Not sure if it will do what you are
asking precisely, but that is where to look …
That step may
Thanks. That is a concern that I will have to address. I need to be able to visualize (in VMD, for example) the results of the simulation within the context of the nucleic acid structure in the solvated system. If the atom type, residue and chain information corresponding to each atom is not retained, I will have to find a way to reclaim it.
I hope the ch2lmp tool will do this …
Jim
(248) 573-5499
