Normally the lj/cut and lj/cut/soft should give the same answers when lambda = 1. I will test this in detail ASAP.
Meanwhile, maybe you could try to use lambda as the parameter being adapted between your initial and final states (from 0 to 1 I suppose) and keep the epsilon and sigma fixed (that’s the idea behind the soft pair styles).
Agilio
Dear Agilio,
First of all, thank you for your help.
As you mentioned the two potentials lead to the same value of U_1 - U_0 when lambda = 1.
I also did some tests using the fix adapt/fep, but it gaves me the same results. I have reworked a little bit my data to compare the results obtained from FDTI with both Lennard-Jones and soft-core potential. I provide you the spreadsheet in attached.
It is organized as follow :
- In the left hand side of the spreadsheet are reported different thermodynamic outputs (kinetic, potential and total energy, fep1 fep2 and fep3 as defined in the lammps manual), for both soft-core and Lennard-Jones potential. The next columns corresponds to the weight coefficient for the integration (wi) and du/dlambda obtained from fep1 and fep2 ;
- Then, on to right hand side of the sheet are reported the results : excess chemical potential, and for the problem I’m interested in, the fugacity in both lammps and « user friendly » units ;
revue-fep-fdti-ti.ods (32.7 KB)
Hi Julien,
I’ve looked at the spreadsheet you sent with the results and have two questions:
- 700 K may be a stretch for OPLS-AA, which is parameterised at milder conditions. Could it be that the divergence when using lj/cut when lambda -> 0 leads to a value closer to experiment just by accident? The curve using the soft-core potential looks much better behaved.
- how did you change your parameters when using lj/cut? Linearly epsilon leaving sigma constant?
Agilio
Hi Agilio,
What was struggling me with the results for the softcore potential was that the factor exp(mu_res / kt) was close to unity, which (if the results are correct) would indicate that the fluid is close to an ideal gas. But, I will relaunch new simulations to check that point. Similarly to the examples you provided in the lammps distribution, I will try to determine the solvation free energy of heptane in liquid water at 300K.
Yes, this is exactly what I did : varying epsilon at constant sigma. In that case, lambda corresponds to the prefactor used to scale the epsilon, lambda varying from 0 to 1. As it can be seen from the spreadsheet, I made a denser sampling between lambda = 0 and lambda = 0.1 due to the strong variation of the slope of the curve in that range.
Thanks for your help,
Best regards.
