Hi lammps users and developers,
My question is very puntual: Exist any form to define a epsilon parameter of wall-atom pair (using wall potential, 10-4-3).
I defined a epsilon parameter for wall, and use mix-rule to define the parameters with other atoms.But I need a fix value to particular pair.
Thanks for advice.
from this it is not very clear what you are asking:
is it that you want to have a different wall - atom interaction for
different types of atoms?
if yes, then you just define a group for each of these atom types and
the a wall acting on each of these groups with different parameters at
the same location.
