Hi Ovito users,
I am using ovito python lib to compute surfaces from LAMMPS data/dump files. However, I would like to export only top or bottom faces without cap polygons at PBC in vtk format. Disabling the periodic boundary is not a valid option because this changes the computed surface. Also using
modifier.vis.show_cap = False
appears to have no effect on the vtk output from export_file
. Is there a way to pass it as an option even if is_closed = True
