I am quite new to OVITO and I face a problem while exporting surface mesh data. I am using OVITO v3.12.2 the basic GUI version.
What I look for might be part of OVITO Pro already but anyways I am adding some details to my post just in case you might require it. I am uploading bunch of data and applying modifiers before I create the surface mesh. Below I add a summary. The data I work on is a LAMMPS dump file.
- I read a LAMMPS dump file that contains the trajectories of the particles Specifically;
id - mol - type - x - y - z - ix - iy - iz - vx - vy - vz - Then I read another dump file that contains the bond data using the load trajectory modifier. The dump file looks like this.
particle id1 - particle id2 - bond type
Of course dump files include necessary headers generated by LAMMPS. - I replicate the simulation domain into positive and negative z direction by the replicate modifier.
- I apply the following expression selection : Position.X < 50 || Position.X > 140 || Position.Y > 10 || Position.Z < 0 || Position.Z > 30.
- I delete the selected.
- I use the cluster analysis modifer based upon the bonds.
7,8) I apply this expression selection; Cluster > 10 and delete selected.
At the final stage I create a surface mesh using the construct surface mesh modifier with probe radius 0.5 and a smoothing level of 4. I then transfer particle properties to surface. This modifer creates a surfaces tab where I can see the coordinates of the nodal points of the surface triangulation and the cluster they belong. Now if I know which triangle belongs to what cluster I can calculate the surface area of the aggregates and/or calculate the volume enclosed by the surface. However I cannot export this data appering under the surfaces tab. Is there a way to export this using the GUI? Should I switch to API? Is it already part of OVITO Pro?
Thanks in advance.
