I’m trying to extract a neighbor list array for every atom using the LAMMPS C++ library, in a similar way that pair styles access the neighbor list during force and energy calculation. Here’s a minimum example of code:
#include
#include “mpi.h”
#include “lammps.h”
#include “input.h”
#include “atom.h”
#include “library.h”
using namespace LAMMPS_NS;
char *args1[] = {
(char *) “lmp”,
(char ) “-screen”,
(char) “none”,
0};
LAMMPS *lmp;
int main(int argc, char **argv)
int color,key,global,local;
MPI_Comm comm;
/* Initialize MPI */
MPI_Init(&argc,&argv);
/* Split the communicators so that multiple instances of LAMMPS can be run */
MPI_Comm_rank(MPI_COMM_WORLD, &global);
color = global / 1; // Change “1” to 2 in order to use 2 procs per instance, etc…
key = global;
MPI_Comm_split(MPI_COMM_WORLD, color, key, &comm);
MPI_Comm_rank(comm,&local);
/* Create LAMMPS object */
lmp = new LAMMPS(3,args1,comm);
/* Set up system */
lmp->input->one(“neighbor 0.0 bin”);
lmp->input->one("boundary p p p ");
lmp->input->one(“units metal”);
lmp->input->one(“atom_style atomic”);
lmp->input->one(“atom_modify map array”);
lmp->input->one(“region box prism 0 1 0 1 0 1 0 0 0 units lattice”);
lmp->input->one(“create_box 1 box”);
lmp->input->one(“create_atoms 1 random 100 10101 NULL”);
/* Get neighbors for every atom /
/ ??? How to do this ??? */
/* Delete LAMMPS object */
delete lmp;
/* Close MPI */
int MPI_Comm_free(MPI_Comm *comm);
MPI_Finalize();
This short script can be compiled with the attached Makefile (just set the LAMMPS directory and shared library paths).
After creating the LAMMPS pointer, I set up a simple system of 100 randomly placed atoms in a simple box. I can easily access per-atom quantities now via lmp->atom, for example. But how can I compute and access the neighbor list for every atom in this system? I don’t necessarily even want to declare a pair style, even though it may be necessary. For example, the 2-body neighbor list in the Morse pair style is accessed via:
inum = list->inum;
ilist = list->ilist;
numneigh = list->numneigh;
firstneigh = list->firstneigh;
But I don’t have access to the “list” pointer in my code, nor do I know how to build a neighbor list using the C++ library.
I’ve thought about making a custom pair style that just gets the neighbor list, and then retrieving that list with via pointer in my main code. I was just wondering if there was a more simple solution.
Thanks for your time.
Makefile (267 Bytes)
