Hi everyone.
I was working on a LAMMPS project where the goal is to simulate the diffusion coefficients of oxygen and carbon dioxide in polyurethane membranes.
While running my project, the density dropped from a good 1.22g/cm^3 to a 0.4g/cm^3. Alongside it, there was an extreme pressure drop and overall, it is very concerning.
Below is the LAMMPS input script. Hopefully someone can help.
# INITIALIZATION
units real
atom_style full
# Initial force field settings
pair_style lj/cut/coul/long 12.0
bond_style harmonic
angle_style harmonic
dihedral_style opls
kspace_style pppm 1.0e-4
special_bonds lj/coul 0.0 0.0 0.5
comm_modify cutoff 6.0
# READ DATA & FORCE FIELDS
read_data polyurethane_realistic.data
# Pair coefficients
include file.txt
# Bond coefficients
bond_coeff 1 320.0000 1.4100 # C_alk-O_eth
bond_coeff 2 340.0000 1.0900 # C_alk-H_alk
bond_coeff 3 268.0000 1.5290 # C_alk-C_alk
bond_coeff 4 214.0000 1.3270 # C_carb-O_eth
bond_coeff 5 570.0000 1.2290 # C_carb-O_carb
bond_coeff 6 490.0000 1.3350 # C_carb-N_amide
bond_coeff 7 300.0000 1.5000 # H_amide-N_amide
bond_coeff 8 300.0000 1.5000 # C_arom-N_amide
bond_coeff 9 469.0000 1.4000 # C_arom-C_arom
bond_coeff 10 367.0000 1.0800 # C_arom-H_arom
bond_coeff 11 300.0000 1.5000 # C_alk-C_arom
bond_coeff 12 1000.0000 1.2100 # O_gas-O_gas (stronger for O2)
bond_coeff 13 1000.0000 1.1600 # C_gas-O_gas (stronger for CO2)
# Angle coefficients
angle_coeff 1 50.0000 109.5000 # H_alk-C_alk-O_eth
angle_coeff 2 50.0000 109.5000 # C_alk-C_alk-O_eth
angle_coeff 3 50.0000 109.5000 # H_alk-C_alk-H_alk
angle_coeff 4 50.0000 109.5000 # C_alk-C_alk-H_alk
angle_coeff 5 50.0000 109.5000 # C_alk-C_alk-C_alk
angle_coeff 6 60.0000 109.5000 # C_alk-O_eth-C_alk
angle_coeff 7 60.0000 109.5000 # C_alk-O_eth-C_carb
angle_coeff 8 80.0000 120.0000 # O_carb-C_carb-O_eth
angle_coeff 9 80.0000 120.0000 # N_amide-C_carb-O_eth
angle_coeff 10 80.0000 120.5000 # N_amide-C_carb-O_carb
angle_coeff 11 50.0000 121.9000 # C_carb-N_amide-H_amide
angle_coeff 12 50.0000 121.9000 # C_arom-N_amide-C_carb
angle_coeff 13 50.0000 121.9000 # C_arom-N_amide-H_amide
angle_coeff 14 70.0000 120.0000 # C_arom-C_arom-N_amide
angle_coeff 15 70.0000 120.0000 # C_arom-C_arom-H_arom
angle_coeff 16 70.0000 120.0000 # C_arom-C_arom-C_arom
angle_coeff 17 70.0000 120.0000 # C_alk-C_arom-C_arom
angle_coeff 18 50.0000 109.5000 # C_arom-C_alk-H_alk
angle_coeff 19 50.0000 109.5000 # C_arom-C_alk-C_arom
# Dihedral coefficients
dihedral_coeff * 1.0 1.0 1.0 0.0
# GROUPS
group oxygen type 10
group co2 type 11
group polymer type 1 2 3 4 5 6 7 8 9
# SETTINGS
neighbor 2.0 bin
timestep 0.1
# STAGE 1: OVERLAP REMOVAL (Soft Potential Push-off)
print "========================================="
print "STAGE 1: Removing overlaps with soft potential"
# Temporarily disable long-range electrostatics and switch to soft potential
kspace_style none
pair_style soft 2.5
pair_coeff * * 0.0
variable pre equal ramp(0,100)
fix SOFT all adapt 1 pair soft a * * v_pre
fix LIMIT all nve/limit 0.05
thermo 500
thermo_style custom step temp density press pe ke
run 10000
unfix SOFT
unfix LIMIT
# CRITICAL: RESTORE ORIGINAL FORCE FIELD
print "RESTORING FULL FORCE FIELD"
include file.txt # Restore pair coefficients
# STAGE 2: ENERGY MINIMIZATION
print "STAGE 2: Energy minimization"
minimize 1.0e-4 1.0e-6 1000 10000
# STAGE 3: NVT EQUILIBRATION (Temperature)
print "STAGE 3: NVT equilibration at 310.15 K"
reset_timestep 0
timestep 0.5
fix NVT all nvt temp 310.15 310.15 50.0
thermo 1000
thermo_style custom step temp density press pe ke etotal vol
run 100000
unfix NVT
# STAGE 4: NPT EQUILIBRATION (Pressure & Density)
print "STAGE 4: NPT equilibration at 1 atm"
reset_timestep 0
timestep 1.0
# Use moderate damping parameters for stable equilibration
fix NPT all npt temp 310.15 310.15 100.0 iso 1.0 1.0 500.0 drag 1.0
thermo 2000
run 500000
# Continue NPT with finer control
unfix NPT
fix NPT2 all npt temp 310.15 310.15 100.0 iso 1.0 1.0 1000.0 drag 2.0
run 500000
unfix NPT2
# STAGE 5: PRODUCTION RUN (Diffusion Calculation)
print "STAGE 5: Production run - Calculating diffusion"
reset_timestep 0
# Compute MSD with center-of-mass correction
compute mO2 oxygen msd com yes
compute mCO2 co2 msd com yes
# Calculate diffusion coefficients on-the-fly
# D = MSD / (6*t), units: A^2/fs → multiply by 1e-1 for cm^2/s
variable diff_O2 equal c_mO2[4]/6/(step*dt+1.0e-6)
variable diff_CO2 equal c_mCO2[4]/6/(step*dt+1.0e-6)
# Production NVT ensemble
fix PROD all nvt temp 310.15 310.15 100.0
# Output MSD data
fix WRITE all ave/time 1 1 5000 c_mO2[4] c_mCO2[4] v_diff_O2 v_diff_CO2 &
file msd_results.txt
# Trajectory output
dump 1 all custom 10000 trajectory.lammpstrj id type x y z
# Thermodynamic output
thermo 5000
thermo_style custom step temp density press c_mO2[4] c_mCO2[4] v_diff_O2 v_diff_CO2
run 5000000
print "SIMULATION COMPLETE"
Thank you very much in advance.
Micah
