fatal: not a git repository
Hi!
I just installed v1.9.7, and when I tried to install a model, I get the following error. Am I doing something wrong?
$ kim-api-v1-collections-management install system --sudo EDIP_BOP_Bazant_Kaxiras_Si__MO_958932894036_001
Enter Password :
Downloading… EDIP_BOP_Bazant_Kaxiras_Si__MO_958932894036_001
fatal: not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
Not a git repository
To compare two paths outside a working tree:
usage: git diff [–no-index]
make: lib/kim-api-v1/kim-api-v1-collections-info: Command not found
/usr/lib/kim-api-v1/build_system/Makefile.ParameterizedModel:220: *** Invalid config file. Stop.
Item ‘EDIP_BOP_Bazant_Kaxiras_Si__MO_958932894036_001’ of unknown type ‘’.
Aborting!
Hello Vishnu,
I'm not sure what is happening there. I just checked this and it seems to be working fine for me. Can you detail exactly the steps you have taken to build and install kim-api-v1.9.7?
Ryan
Hi Ryan,
I used the ‘make’ method (since the pre-v2 doesn’t seem to use cmake), and did the following:
./configure --prefix="/usr" --libexecdir="lib" make make install
Hi Vishnu,
Try using:
./configure --prefix="/usr" --libexecdir="/usr/lib"
instead.
Ryan
That still gives me the same error. But no worries, turns out LAMMPS is building in support for the v2 API, and that version works fine for me, so I think I will just wait.
Thanks for your time!
OK,
Sounds good.
Cheers,
Ryan
