ffield.reaxc
The following file ffield.reaxc is needed with reax/c. It includes all force field parameters:
Reactive MD-force field: Cu/S/C/H force field, Yeon et al. 2017
39 ! Number of general parameters
50.0000 !Overcoordination parameter
9.5469 !Overcoordination parameter
26.5405 !Valency angle conjugation parameter
1.7224 !Triple bond stabilisation parameter
6.8702 !Triple bond stabilisation parameter
60.4850 !C2-correction
1.0588 !Undercoordination parameter
4.6000 !Triple bond stabilisation parameter
12.1176 !Undercoordination parameter
13.3056 !Undercoordination parameter
-70.5044 !Triple bond stabilization energy
0.0000 !Lower Taper-radius
10.0000 !Upper Taper-radius
2.8793 !Not used
33.8667 !Valency undercoordination
6.0891 !Valency angle/lone pair parameter
1.0563 !Valency angle
2.0384 !Valency angle parameter
6.1431 !Not used
6.9290 !Double bond/angle parameter
0.3989 !Double bond/angle parameter: overcoord
3.9954 !Double bond/angle parameter: overcoord
-2.4837 !Not used
5.7796 !Torsion/BO parameter
10.0000 !Torsion overcoordination
1.9487 !Torsion overcoordination
-1.2327 !Conjugation 0 (not used)
2.1645 !Conjugation
1.5591 !vdWaals shielding
0.1000 !Cutoff for bond order (*100)
2.1365 !Valency angle conjugation parameter
0.6991 !Overcoordination parameter
1.8512 !Valency/lone pair parameter
0.5000 !Not used
20.0000 !Not used
5.0000 !Molecular energy (not used)
0.0000 !Molecular energy (not used)
2.6962 !Valency angle conjugation parameter
7 ! Nr of atoms; cov.r; valency;a.m;Rvdw;Evdw;gammaEEM;cov.r2;#
alfa;gammavdW;valency;Eunder;Eover;chiEEM;etaEEM;n.u.
cov r3;Elp;Heat inc.;n.u.;n.u.;n.u.;n.u.
ov/un;val1;n.u.;val3,vval4
C 1.3817 4.0000 12.0000 1.8903 0.1838 0.6544 1.1341 4.0000
9.7559 2.1346 4.0000 34.9350 79.5548 5.4088 6.0000 0.0000
1.2114 0.0000 202.2908 8.9539 34.9289 13.5366 0.8563 0.0000
-2.8983 2.5000 1.0564 4.0000 2.9663 0.0000 0.0000 0.0000
H 0.8930 1.0000 1.0080 1.3550 0.0930 0.8203 -0.1000 1.0000
8.2230 33.2894 1.0000 0.0000 121.1250 3.7248 9.6093 1.0000
-0.1000 0.0000 55.6606 3.0408 2.4197 0.0003 1.0698 0.0000
-19.4571 4.2733 1.0338 1.0000 2.8793 0.0000 0.0000 0.0000
O 1.2450 2.0000 15.9990 2.3890 0.1000 1.0898 1.0548 6.0000
9.7300 13.8449 4.0000 37.5000 116.0768 8.5000 8.3122 2.0000
0.9049 0.4056 63.0626 3.5027 0.7640 0.0021 0.9745 0.0000
-3.5500 2.9000 1.0493 4.0000 2.9225 0.0000 0.0000 0.0000
S 1.7971 2.0000 32.0660 2.0914 0.2269 1.0532 1.7377 6.0000
9.0000 5.4206 4.0000 14.8039 0.0000 5.8930 7.0000 0.0000
-1.0000 0.0000 0.0000 20.4140 3.3754 0.2702 0.0000 0.0000
-6.5738 1.5000 0.0000 4.0000 13.6585 0.0000 0.0000 0.0000
Cu 1.9202 2.0000 63.5460 1.9221 0.2826 1.0000 0.1000 1.0000
10.9889 100.0000 1.0000 0.0000 0.0000 2.7875 6.0000 0.0000
-1.0000 0.0000 80.7000 34.9555 0.4988 0.0000 0.8563 0.0000
-5.1872 3.1491 1.0000 4.0000 2.5791 0.0000 0.0000 0.0000
Cl 1.7140 1.0000 35.4500 1.9139 0.2000 0.3837 -1.0000 7.0000
11.5345 10.1330 1.0000 0.0000 0.0000 9.9614 6.5316 0.0000
-1.0000 3.5750 143.1770 6.2293 5.2294 0.1542 0.8563 0.0000
-10.2080 2.9867 1.0338 6.2998 2.5791 0.0000 0.0000 0.0000
X -0.0998 2.0000 1.0080 2.0000 0.0000 1.0000 -0.1000 6.0000
10.0000 2.5000 4.0000 0.0000 0.0000 8.5000 1.5000 0.0000
-0.1000 0.0000 -2.3700 8.7410 13.3640 0.6690 0.9745 0.0000
-11.0000 2.7466 1.0338 4.0000 2.8793 0.0000 0.0000 0.0000
19 ! Nr of bonds; Edis1;LPpen;n.u.;pbe1;pbo5;13corr;pbo6
pbe2;pbo3;pbo4;Etrip;pbo1;pbo2;ovcorr
1 1 158.2004 99.1897 78.0000 -0.7738 -0.4550 1.0000 37.6117 0.4147
0.4590 -0.1000 9.1628 1.0000 -0.0777 6.7268 1.0000 0.0000
1 2 169.4760 0.0000 0.0000 -0.6083 0.0000 1.0000 6.0000 0.7652
5.2290 1.0000 0.0000 1.0000 -0.0553 6.9316 0.0000 0.0000
2 2 153.3934 0.0000 0.0000 -0.4600 0.0000 1.0000 6.0000 0.7300
6.2500 1.0000 0.0000 1.0000 -0.0790 6.0552 0.0000 0.0000
1 3 100.9167 136.3836 65.3877 0.3895 -0.3906 1.0000 18.8159 0.6674
1.1202 -0.3411 9.1099 1.0000 -0.1966 5.6975 0.0000 0.0000
2 3 160.0000 0.0000 0.0000 -0.5725 0.0000 1.0000 6.0000 0.5626
1.1150 1.0000 0.0000 0.0000 -0.0920 4.2790 0.0000 0.0000
3 3 142.2858 145.0000 50.8293 0.2506 -0.1000 1.0000 29.7503 0.6051
0.3451 -0.1055 9.0000 1.0000 -0.1225 5.5000 1.0000 0.0000
1 4 196.8295 72.4427 35.7881 -0.7046 -0.3246 1.0000 28.2781 0.0500
0.0702 -0.2365 9.2970 1.0000 -0.1715 4.6483 1.0000 0.0000
2 4 164.1121 0.0000 0.0000 -0.2327 0.1000 1.0000 6.0324 0.3826
1.8890 1.0109 -0.0340 1.0000 -0.1359 4.5933 0.0000 0.0000
3 4 0.0000 0.0000 0.0000 0.5563 -0.4038 1.0000 49.5611 0.6000
0.4259 -0.4577 12.7569 1.0000 -0.1100 7.1145 1.0000 0.0000
4 4 99.1559 72.9102 0.0000 -0.9289 -0.4781 1.0000 17.8574 0.3242
0.3164 -0.1900 8.3634 1.0000 -0.1799 5.7204 1.0000 0.0000
1 5 55.2883 0.0000 0.0000 0.7754 -0.1418 1.0000 13.1260 0.0511
1.1934 -0.2000 20.0000 1.0000 -0.0980 7.7741 0.0000 0.0000
2 5 12.7278 0.0000 0.0000 0.4667 -0.1418 1.0000 13.1260 0.2398
0.5733 -0.2000 20.0000 1.0000 -0.0517 9.6453 0.0000 0.0000
3 5 81.4346 0.0000 0.0000 -0.1594 -0.3000 1.0000 36.0000 0.0025
0.2904 -0.2500 12.0000 1.0000 -0.0742 9.3638 0.0000 0.0000
4 5 103.4193 1.0000 0.0000 -0.6129 -0.2000 0.0000 16.0000 0.2321
0.1378 -0.2467 14.3235 1.0000 -0.1076 5.5910 0.0000 0.0000
5 5 73.6263 0.0000 0.0000 0.0209 -0.2000 0.0000 16.0000 0.3414
0.4703 -0.2000 15.0000 1.0000 -0.1319 5.9254 0.0000 0.0000
2 6 109.1686 0.0000 0.0000 -0.1657 -0.2000 0.0000 16.0000 1.2500
2.8463 -0.2000 15.0000 1.0000 -0.1111 5.2687 0.0000 0.0000
3 6 0.0000 0.0000 0.0000 0.5000 -0.2000 0.0000 16.0000 0.5000
1.0001 -0.2000 15.0000 1.0000 -0.1000 10.0000 0.0000 0.0000
5 6 118.3052 0.0000 0.0000 -0.1168 -0.2000 0.0000 16.0000 0.0697
2.9176 -0.2000 15.0000 1.0000 -0.1316 5.3624 0.0000 0.0000
6 6 0.2500 0.0000 0.0000 0.1803 -0.2000 0.0000 16.0000 0.3356
0.9228 -0.2000 15.0000 1.0000 -0.1178 5.6715 0.0000 0.0000
13 ! Nr of off-diagonal terms; Ediss;Ro;gamma;rsigma;rpi;rpi2
1 2 0.1239 1.4004 9.8467 1.1210 -1.0000 -1.0000
1 3 0.0647 2.0109 10.0105 1.3177 1.2052 1.0682
1 4 0.1509 2.0454 10.9155 1.4817 1.3631 -1.0000
1 5 0.0594 2.2738 8.0000 1.5151 -1.0000 -1.0000
2 3 0.0283 1.2885 10.9190 0.9215 -1.0000 -1.0000
2 4 0.1807 1.7365 9.1782 1.2597 -1.0000 -1.0000
2 5 0.3500 1.6000 9.2813 1.5008 -1.0000 -1.0000
3 4 0.1022 1.9887 10.0605 1.5799 1.4000 -1.0000
3 5 0.0348 1.7637 12.3562 1.7228 -1.0000 -1.0000
4 5 0.1602 1.6724 12.9384 1.7177 1.2000 -1.0000
2 6 0.0568 1.6740 9.6297 1.2200 -1.0000 -1.0000
3 6 0.1927 2.2551 11.2308 -1.0000 -1.0000 -1.0000
5 6 0.1402 2.1604 10.9786 1.7505 -1.0000 -1.0000
53 ! Nr of angles;at1;at2;at3;Thetao,o;ka;kb;pv1;pv2
1 1 1 59.0573 30.7029 0.7606 0.0000 0.7180 6.2933 1.1244
1 1 2 65.7758 14.5234 6.2481 0.0000 0.5665 0.0000 1.6255
2 1 2 70.2607 25.2202 3.7312 0.0000 0.0050 0.0000 2.7500
1 2 2 0.0000 0.0000 6.0000 0.0000 0.0000 0.0000 1.0400
1 2 1 0.0000 3.4110 7.7350 0.0000 0.0000 0.0000 1.0400
1 1 3 66.0686 28.5756 1.4793 0.0000 2.9950 58.6562 1.0000
3 1 3 84.3310 21.5172 5.4724 -1.0000 1.5183 0.0000 2.9776
2 1 3 64.3088 32.5434 2.1997 0.0000 0.1000 0.0000 1.2995
1 3 1 68.4903 45.0000 1.3617 0.0000 2.8294 0.0000 1.0000
1 3 3 80.6161 45.0000 1.4073 0.0000 1.0572 68.1072 1.4451
2 2 2 0.0000 27.9213 5.8635 0.0000 0.0000 0.0000 1.0400
3 3 3 89.9934 17.9465 1.7798 0.0000 2.9881 0.0000 1.0538
1 3 2 90.0000 7.1513 7.5000 0.0000 1.3111 0.0000 3.0000
2 3 3 75.6935 50.0000 2.0000 0.0000 1.0000 0.0000 1.1680
2 3 2 85.8000 9.8453 2.2720 0.0000 2.8635 0.0000 1.5800
1 2 3 0.0000 8.9481 0.5983 0.0000 0.0000 0.0000 1.0000
1 2 4 0.0000 15.0000 3.0000 0.0000 0.0000 0.0000 1.0400
3 2 3 0.0000 15.0000 2.8900 0.0000 0.0000 0.0000 2.8774
2 2 3 0.0000 8.5744 3.0000 0.0000 0.0000 0.0000 1.0421
1 1 4 70.8401 24.2354 1.1433 0.0000 0.0050 0.0000 1.0010
1 4 1 86.8019 26.9212 1.8331 0.1463 0.4821 0.0000 2.0005
2 1 4 76.6832 34.5823 0.1000 0.0000 0.0050 0.0000 3.0000
1 4 2 77.2870 5.0000 4.1470 0.0000 2.8195 0.0000 1.0010
1 4 4 83.6692 39.6168 2.3105 0.1463 0.1876 0.0000 1.7186
2 4 2 67.1975 11.4189 7.0000 0.0000 0.1356 0.0000 1.0010
2 4 4 100.0000 35.9584 4.9740 0.0000 2.4915 0.0000 1.1067
2 2 4 0.0000 0.0019 6.0000 0.0000 0.0000 0.0000 1.0400
1 3 5 55.0000 15.0000 1.0000 0.0000 1.0000 0.0000 1.5000
3 5 3 96.2265 4.5610 12.0000 0.0000 0.3211 0.0000 1.5204
3 5 3 0.0000 9.1552 7.9919 0.0000 0.1660 0.0000 1.5386
5 3 5 100.0000 10.1065 6.0000 0.0000 1.0000 0.0000 3.6601
2 3 5 55.0417 3.5032 3.9979 0.0000 1.5171 0.0000 1.0400
3 3 5 70.0000 30.0000 2.0000 0.0000 1.0000 0.0000 1.2500
3 5 5 66.7783 14.3146 0.7911 0.0000 1.0000 0.0000 1.2333
1 4 5 68.1443 30.9105 1.1419 0.1463 2.2697 0.0000 2.4778
4 5 4 66.0574 23.1328 7.0000 0.0000 1.3934 0.0000 4.0000
5 4 5 119.6129 17.0322 4.7434 0.0000 0.0535 0.0000 1.0253
4 5 5 45.4235 4.0404 0.6655 0.0000 0.5297 0.0000 1.0622
4 4 5 69.9353 50.0000 7.0000 0.0000 2.1023 0.0000 1.6959
1 5 1 38.5161 8.3413 0.3621 0.0000 0.8830 0.0000 1.4556
5 1 5 89.6232 23.7372 0.0100 0.0000 0.2934 0.0000 2.5681
1 5 5 62.8895 7.8988 1.7461 0.0000 4.3892 0.0000 2.1390
1 1 5 90.9978 1.7922 0.0959 0.0000 2.1225 0.0000 1.1785
3 5 6 96.6924 9.4823 5.7883 0.0000 0.2248 0.0000 2.2640
3 5 6 0.0000 3.8549 3.7230 0.0000 0.1482 0.0000 1.0400
5 6 5 0.0000 11.2336 6.8851 0.0000 1.0000 0.0000 1.0893
5 5 6 90.0000 5.0811 5.2147 0.0000 1.0000 0.0000 1.8538
6 5 6 0.0100 21.1482 0.3506 0.0000 1.0000 0.0000 1.4361
3 2 6 0.0000 0.0100 0.5211 0.0000 0.0000 0.0000 1.3859
2 5 2 40.9054 6.5138 3.0571 0.0000 4.0958 0.0000 1.9830
5 2 5 93.4818 27.6107 0.0100 0.0000 1.3897 0.0000 1.4564
2 5 5 43.8466 25.4703 4.0334 0.0000 1.8688 0.0000 1.0000
2 2 5 96.6789 1.2930 4.1372 0.0000 3.1430 0.0000 1.0062
30 ! Nr of torsions;at1;at2;at3;at4;;V1;V2;V3;V2(BO);vconj;n.u;n
1 1 1 1 -0.2500 34.7453 0.0288 -6.3507 -1.6000 0.0000 0.0000
1 1 1 2 -0.2500 29.2131 0.2945 -4.9581 -2.1802 0.0000 0.0000
2 1 1 2 -0.2500 31.2081 0.4539 -4.8923 -2.2677 0.0000 0.0000
1 1 1 3 -0.5740 22.4215 0.8787 -2.7603 -1.1000 0.0000 0.0000
2 1 1 3 1.8164 18.8479 0.5134 -7.0513 -1.0978 0.0000 0.0000
3 1 1 3 -2.5000 56.1599 -1.0000 -4.3607 -0.8614 0.0000 0.0000
1 1 3 1 2.5000 14.6490 1.0000 -2.5209 -0.9000 0.0000 0.0000
1 1 3 3 -0.0002 20.1851 0.1601 -9.0000 -2.0000 0.0000 0.0000
1 3 3 1 0.0002 80.0000 -1.5000 -4.4848 -2.0000 0.0000 0.0000
3 1 3 3 -0.1583 20.0000 1.5000 -9.0000 -2.0000 0.0000 0.0000
1 1 3 2 -2.2946 11.6826 -1.0000 -2.5000 -0.9000 0.0000 0.0000
2 1 3 1 -1.0402 26.8401 0.6384 -2.5000 -0.9000 0.0000 0.0000
2 1 3 2 -1.0000 66.0304 0.7580 -5.4593 -1.1000 0.0000 0.0000
2 1 3 3 2.1531 45.9655 1.0000 -2.5000 -2.8274 0.0000 0.0000
3 1 3 1 0.6706 80.0000 -0.2443 -4.7181 -3.0437 0.0000 0.0000
3 1 3 2 -1.0000 91.6742 -0.5000 -3.9849 -3.0476 0.0000 0.0000
1 3 3 2 -2.5000 -0.5181 0.0268 -5.4085 -2.9498 0.0000 0.0000
2 3 3 2 -2.1995 -25.0000 -1.0000 -2.6000 -0.9921 0.0000 0.0000
2 3 3 2 2.5000 -4.0000 0.9000 -2.5000 -1.0000 0.0000 0.0000
2 3 3 3 0.8302 -4.0000 -0.7763 -2.5000 -1.0000 0.0000 0.0000
3 3 3 3 -2.5000 -4.0000 1.0000 -2.5000 -1.0000 0.0000 0.0000
0 2 2 0 0.0000 0.0000 0.0000 0.0000 -1.2327 0.0000 0.0000
0 2 3 0 0.0000 0.1000 0.0200 -2.5415 -1.2327 0.0000 0.0000
0 3 3 0 0.5511 25.4150 1.1330 -5.1903 -1.0000 0.0000 0.0000
0 1 1 0 0.0000 50.0000 0.1000 -5.0000 0.0000 0.0000 0.0000
0 1 4 0 -0.2500 67.6158 1.0000 -3.0885 -1.3684 0.0000 0.0000
0 4 4 0 0.1181 16.5024 0.5510 -8.2057 -1.0061 0.0000 0.0000
4 4 4 4 0.0100 30.0000 0.1000 -8.0000 0.0000 0.0000 0.0000
2 3 5 3 -1.5000 6.8333 -0.1978 -1.4683 0.0000 0.0000 0.0000
2 3 5 6 0.1589 12.5000 0.4388 -1.5000 0.0000 0.0000 0.0000
4 ! Nr of hydrogen bonds;at1;at2;at3;Rhb;Dehb;vhb1
3 2 3 2.1200 -3.5800 1.4500 19.5000
3 2 4 1.5000 -2.0000 1.4500 19.5000
4 2 3 1.5000 -2.0000 1.4500 19.5000
4 2 4 1.5000 -2.0000 1.4500 19.5000
But which element does ‘X’ (marked in atom parameter section)stand for ?
In addition, I know ‘4 4 4 4’ in torsion parameter section stands for ‘S-S-S-S’ torsion type, but what does ‘0 4 4 0’ means? Thank you!
Jie Wang
X doesn’t represent any element. Zeroes in dihedral angles mean any element. More about the reaxFF parameter files can be found here: https://www.scm.com/wp-content/uploads/ReaxFF-users-manual-2002.pdf
Michal
